Narrow Carbon Clinchers to fit 2009 S-Works Tarmac SL2
Fitzroy
by Fitzroy
Hi All,
Struggling to find a rim brake, tubeless ready, carbon rim (40 to 50mm) to fit the narrow chainstay (about 30mm at there narrowist point) on my old tramac SL2. Had some 404's but they rubbed the stays on climbs, ran fine on the flats. Current Alloy rims are 24mm wide at the brake track running GP5000TL.
After Rims only if possible to build to a set of WI T11 (24/28). Everything I look at are 26mm or larger or start at the top brake track around 25mm then do that tordinal thing and end up 28mm in the middle.
If anyone has recently gone through the same process please let me know options, chinese or otherwise.
Cheers.
Matt28NJ
by Matt28NJ
I have a 2009 Tarmac Pro (same mold) and I have been able to get a Light-Bicycle AR56 28mm wide wheelset on there with 25mm GP4k Tires. It's a tight fit at the chainstays, but it works.
My 2014 Venge (rim brake) has way more clearance.
Fitzroy
by Fitzroy
Matt28NJ wrote:
Sat Sep 10, 2022 4:15 pm
Thanks Matt, if these are the same ones you mentioned https://www.lightbicycle.com/45mm-deep- ... rface.html they were top of my list but was worried about the 27.3mm max width. Hoping with the 28hole rear lacing it shouldn't be an issue.
alanyu
by alanyu
Farsports should still have some 23 mm wide rims. You may drop them an email
Matt28NJ
by Matt28NJ
Fitzroy wrote:
Sun Sep 11, 2022 3:38 am
Those were not the AR56s you linked to. This is it: https://www.lightbicycle.com/700C-V-sha ... tible.html This is the model I have currently on my Tarmac.
FYI, the chainstay clearance as you've noted is very tight. Your wheels will need to be maintained and trued if they go out of spec or there is a possibility of chain stay rub. After a season of racing, my rear wheel is out of true, but not horribly, and still clears the chainstay.
