Which Alloy Clincher Rim Wheels? Any hub, any rim....
RTW
by RTW
So I am building a steel rim brake build because, well, I have other bikes, but not a steel rim brake one!
In all likelihood it will be Super Record mechanical. This is an analogue bike, so I don't really want carbon rims....
I would like suggestions for wheels to take 28mm wide tyres. I will rub latex tubes and open tubulars probably. Requirements are:
Campagnolo freehub
Rim brake
Lightweight as possible
Years ago, I had some Tune / CX-Ray / Velocity Aerohead wheels, which were great, but narrow by today's standards.
I am 76 - 80kg depending on how trained I am.
yinya
by yinya
+1 I am also curious
tonchy
by tonchy
Ritchey Zeta Classic:
1444g/set, 20mm internal, with a little search I'm sure, you can find 'em with Campy freehub in stock.
rollinslow
by rollinslow
Campy shamal ultra. Would be amazing in there and be alloy.
Can't wait to see your build!
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
RyanH
by RyanH
I'm running Hed Belgium R laced to Carbon Ti with CX Rays and super happy with the wheels. I think for your build an even shallower rim would look better (maybe Kinlin). The Belgium setup isn't as light as I had hoped, it was around 1450g IIRC.
Sent from my Pixel 5 using Tapatalk
RTW
by RTW
Thanks Ryan - I will take a look.
Also, I miss your instagram.
CyclingGiraffe
by CyclingGiraffe
DT Swiss 411, CX Rays, and DT Swiss 240 or White Industries.
I had a similar build years ago, with a narrower DT Swiss rim and older WI hubs, and I recall them being around 1455g and pretty much bombproof. You could probably get these under 1400 with more exotic hubs, like the DT Swiss 180 or even the Tune Mag 170. You'll likely pay the price in durability, though.
Bigger Gear
by Bigger Gear
I have 2 pair of rim brake HED Belgium+ clinchers (21 mm internal width), built 24f/28r, Sapim CX-Ray with alloy nipples. One set with White Ind T11 hubs, and the other with King R45. Both built by Sugar Wheelworks in Portland, and both have been EXCEPTIONALLY durable. I am about 77 kg and they've seen smooth roads, rough roads, smooth gravel and some moderately rough gravel. I cannot imagine a better everyday wheelset for a rim brake setup.
