I'm trying to figure out how to put back the new 6803 bearings in my old classic DTSwiss 240S rim brake front hub.
I'm thinking:
1) put one side 6803 bearing using my Wheels Manufacturing press and 6803 open bore adaptor.
2) install axle, and put second 6803 bearing, but press using the ... 17mm spacer ??
Please enlighten me
Louis
Bearing replacement on DTSwiss 240 old rim brake front hub
This is how I pressed bearings into my Bontrager wheels with dt240 hubs. Plus any other hub where the axle has a flange on the inside of each bearing. Use the old bearing as a spacer to press in the new one.
