significant play in new Zipp 404 firecrest
whataboutEee
by whataboutEee
I purchased a pair of zipp 404 firecrest a couple months ago, and the front wheel has significant lateral play in the hub. I looked at the specs for the new zr1 hubs and it doesn't look like there is any way to adjust preload other than the wave washer. Before I go thru the hassle of dealing with Sram warranty, I was wondering if anyone had come across this and had an easy fix?
PinaRene
by PinaRene
Lifetime warranty on Zipp wheels. :smartass: .. do you need more info ?
whataboutEee
by whataboutEee
PinaRene wrote:
Sun May 22, 2022 7:41 pm
I know that worst case scenario I'll get a new wheel, I was just hoping there was an easy fix that didn't have me having to deal with the warranty hassle.
Lucendi
by Lucendi
I had a set of 404 NSW wheels and they came brand new with defective bearings in the rear wheel, lots of side to side play.
Bike mechanic said it was typical for Zipp wheels.
SCJKJ
by SCJKJ
You could always replace the bearings and adjust the preload yourself, but if it came like this out of the box I'd ask Zipp for new wheels or that you can bring it to a LBS with them paying the bill.
PinaRene
by PinaRene
@Lucendi : 5 pair of Zipp wheels here, never had one problem .. so easy to say that it's typical for Zipp wheels.
@SCJKJ, new Zipp wheels ( since 77/177 hubs 2017 ) don't have an option to adjust preload on the bearings.
SCJKJ
by SCJKJ
PinaRene wrote:
Tue May 24, 2022 1:39 pm
@Lucendi : 5 pair of Zipp wheels here, neverhad one problem .. so easy to say that it's typical for Zipp wheels.
Ah, ok. Well, my new super-9 disc still has that option, so I assumed others did as well.
whataboutEee
by whataboutEee
just a follow up in case anyone cares. I took the hub apart and it turns out the bearings weren't pressed in fully. Seated the bearings properly and all play is gone.
Aesch
by Aesch
Well done but still a major QC fail if you ask me.
