Too few spokes - what’s the actual problem?
hansotto089
by hansotto089
Hi guys
I have a set of 24H/24H Farsports Carbon wheels with Carbon-Ti hubs that I built up for road cycling & climbing. They are relatively deep (40/50).
Now I am considering to repurpose them as Gravel wheels but am concerned they might not have enough spokes for me as a heavy rider (90 kg) and off-road riding.
First, what’s your take on that?
Second, what’s really the main concern when you don’t have enough spokes - is it that the wheel might not feel stiff enough, or is it really a true reliability concern?
Thanks guys!
HansZuDemFranz
by HansZuDemFranz
The ZIPP 303s, which are (at least partly) gravel wheels also have 24 spokes front and rear with a similar depth. So I wouldnt worry too muhc about that. The only unkown for me are the hubs, as I have no experience with Carbon-Ti hubs for gravel. It also depends on the type of spokes you have, as that can greatly impact the durability.
Aesch
by Aesch
I would say just go for it, if you start to break spokes you know they're the weak spot and you'll have to choose stronger ones and redo the wheel.
My gravel wheels from dt (gr1600) have 24 spokes, strong ones though.
usr
by usr
Why would a set of spokes that's good for high speed cornering with 23mm tires on some remote mountain road that has been crudely patched up over and over again for decades be challenged by cruising trails at moderate speed on cushy wide tires?
TLN
by TLN
I won't go for any lightweight options, but I'm ok with any regular 24/24 options.
His: Orbea Orca OMX
