Removing end caps from Easton front wheel
Nickldn
by Nickldn
As it's dark deep winter in the UK I'd like to check the wheel bearings on my summer bike, but can't remove the end caps from my Easton EC90 front wheel with Echo hub.
The insides are smooth, so no way to unscrew them with a hex key, can't pull them out either.
Does anyone have any ideas?
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Butcher
by Butcher
https://eastoncycling.com/pages/productmanual
Looking at the parts diagram, it does not appear to be any screws. If you have a vise with soft jaws, then you can probably pull off the cap that way.
kervelo
by kervelo
I once used a simple plastic expansion plug to get the end cap out. Like this:
https://www.fischer.co.uk/en-gb/product ... on-plug-sx
The size of the plug should be big enough to barely fit in the end cap hole. Then just screw in a screw and if you are lucky, you can pull out the end cap.
Nickldn
by Nickldn
kervelo wrote:
Tue Jan 18, 2022 9:20 pm
Thank you!
Sounds good, got lots of plastic plugs in the toolbox. I will try that one tomorrow!
Nickldn
by Nickldn
Got one of the end caps off using a small raw plug and screw. In the end it didn't need much force.
There is some grease inside the bearing.
Does this look OK, would it benefit from being re-greased?
