May I ask ballpark what your deal was? (MSRP is 2,500 USD)
SW Aethos build - what wheels?
I'm buying a few components for the build from a LBS (including frameset) so it probably can't be perfectly compared to buying it elsewhere, but they're giving it to me for $2100 for the wheels, Turbo Cotton tires (+ tubes), and rotors. Any other wheelset was going to be full MSRP (presumably because they're a bit Spesh shop, so probably have more of a margin?).
2021 SW Tarmac SL7
2022 SW Aethos
2023 ENVE Mog w/SRAM Red XPLR & 353 NSW
2023 Riese & Muller Supercharger Rohloff HS (aka the tank)
2022 SW Aethos
So I changed things up slightly when all the parts finally arrived earlier this week. My LBS that was sourcing some of the parts for me also got in some new Zipp 353 NSWs and I couldn't pass up going for them. He gave them to me for USD3500, which is no small amount but also a nice discount over MSRP. Also ended up getting the Alpinist bars instead of the stock setup. Otherwise a pretty much stock SRAM Red build. Here are a bunch of pictures of the build:
https://photos.app.goo.gl/J3M3HjUwYRarBSAt9
Came out to just a bit over 14lbs, which I think is acceptable given I made no attempt to optimize for weight.
2021 SW Tarmac SL7
2022 SW Aethos
2022 SW Aethos
Super nice setup and doing something very similar except with shimano. Curious how you like the 353's w/ the Aethos?seinberg wrote: ↑Sat Jan 29, 2022 3:52 pmSo I changed things up slightly when all the parts finally arrived earlier this week. My LBS that was sourcing some of the parts for me also got in some new Zipp 353 NSWs and I couldn't pass up going for them. He gave them to me for USD3500, which is no small amount but also a nice discount over MSRP. Also ended up getting the Alpinist bars instead of the stock setup. Otherwise a pretty much stock SRAM Red build. Here are a bunch of pictures of the build:
Have a look at Spada wheels, still one of local Italian favourite
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
What made the PCWs superior to the other wheels you've ridden ?thebikemanguy wrote: ↑Thu Dec 30, 2021 6:28 amNo experience with the 4550s, but I've ridden both the 6560's and the 4540's and they're the best wheels I've ever been on, hands down. They're honestly a pretty different wheel to the 353s though. The PCWs are narrow by modern standards and are designed to be out-and-out fast all-around/climbing road racing wheels. The zipps are super wide and generally optimized for a broader range of use cases. I'd personally consider that 18.5mm internal width on the PCWs to be a dealbreaker but if you want to run 25s then it wouldn't be as much of an issue. But I also wouldn't be super stoked to spend $4k for a pair of zipp-branded hubs, and that price is still pretty wild even considering the other wheels you've mentioned. Tradeoffs.seinberg wrote: ↑Mon Dec 27, 2021 3:54 amThis is great feedback. I got a private message from someone who suggested looking at the Princeton Peak 4550 wheels as well, which I've thrown into the equation. The Enves look nice too. If Roval had just made the Alpinists tubeless it would make the decision a bit simpler Very curious to hear more personal experiences like yingyu (thanks!). BTW, is beyondaero.com actually trustworthy? I tried looking them up (had never heard of them) and it seems to get a fair number of really negative reviews so while they seem to be the only place with the 353s in stock I'm reluctant to order from them!
Sworks Tarmac SL8 - 7.09kg
LS Ultimate (7.89kg), Tarmac SL7 (7.56kg), Aethos (7.00kg), Venge (7.59 kg), Roubaix Team (7.53 kg) - Sold
To me, they just feel really good under acceleration and hard efforts - they encourage me to ride harder and keep pushing. Perhaps a bit difficult to describe but just a really nice combination of stiffness, weight, and responsiveness. My comparison point are other high end wheels from Reynolds and Zipp. Spec-wise I appreciate that you can choose from the best hubs out there which allows you to tailor the wheels to your needs a little bit - as a smaller rider I went with the Tune hub option (the 6560's were second-hand and came with White Industries hubs). To be honest I *didn't* find the shape to make a big difference in terms of crosswind stability vs other wheelsets at similar depths, in case you were curious about that.wolflikeme wrote: ↑Tue Feb 08, 2022 5:08 amWhat made the PCWs superior to the other wheels you've ridden ?thebikemanguy wrote: ↑Thu Dec 30, 2021 6:28 amNo experience with the 4550s, but I've ridden both the 6560's and the 4540's and they're the best wheels I've ever been on, hands down. They're honestly a pretty different wheel to the 353s though. The PCWs are narrow by modern standards and are designed to be out-and-out fast all-around/climbing road racing wheels. The zipps are super wide and generally optimized for a broader range of use cases. I'd personally consider that 18.5mm internal width on the PCWs to be a dealbreaker but if you want to run 25s then it wouldn't be as much of an issue. But I also wouldn't be super stoked to spend $4k for a pair of zipp-branded hubs, and that price is still pretty wild even considering the other wheels you've mentioned. Tradeoffs.seinberg wrote: ↑Mon Dec 27, 2021 3:54 amThis is great feedback. I got a private message from someone who suggested looking at the Princeton Peak 4550 wheels as well, which I've thrown into the equation. The Enves look nice too. If Roval had just made the Alpinists tubeless it would make the decision a bit simpler Very curious to hear more personal experiences like yingyu (thanks!). BTW, is beyondaero.com actually trustworthy? I tried looking them up (had never heard of them) and it seems to get a fair number of really negative reviews so while they seem to be the only place with the 353s in stock I'm reluctant to order from them!
Congrats . I personally would prefer a more colorful painting scheme but I like the ninja look delivered by the subtle contrast between the frame and the Zipp wheels. Have you got a chance to ride it?seinberg wrote: ↑Sat Jan 29, 2022 3:52 pmSo I changed things up slightly when all the parts finally arrived earlier this week. My LBS that was sourcing some of the parts for me also got in some new Zipp 353 NSWs and I couldn't pass up going for them. He gave them to me for USD3500, which is no small amount but also a nice discount over MSRP. Also ended up getting the Alpinist bars instead of the stock setup. Otherwise a pretty much stock SRAM Red build. Here are a bunch of pictures of the build:
I suspect the new hookless Zipp 454 NSW, which OP already owns, has a ride quality closer to narrower PCW wheels than 353. Do you have experience with 454 NSW vs Grit 4540 or Wake 6560?thebikemanguy wrote: ↑Tue Feb 08, 2022 6:56 amTo me, they just feel really good under acceleration and hard efforts - they encourage me to ride harder and keep pushing. Perhaps a bit difficult to describe but just a really nice combination of stiffness, weight, and responsiveness. My comparison point are other high end wheels from Reynolds and Zipp. Spec-wise I appreciate that you can choose from the best hubs out there which allows you to tailor the wheels to your needs a little bit - as a smaller rider I went with the Tune hub option (the 6560's were second-hand and came with White Industries hubs). To be honest I *didn't* find the shape to make a big difference in terms of crosswind stability vs other wheelsets at similar depths, in case you were curious about that.
Not sure if anyone using Shimano have tried teh new 2021 new 12 speed Shimano Dura Ace C50 or C36. I prefer it better than my PCW 4540 or Hunt 44 with carbon spokes by a far stretch. Ride quality is good, new Shimano Dura Ace Hub is rock solid ....as good as Bora Ultra by ride feel/rolling. But wheelset ride is not as harsh as a 45/60 Bora Ultra
- Moderator
Interesting to hear Shimano have finally managed a decent set of wheels .. I do like the look of the 60smaxima wrote: ↑Mon May 16, 2022 10:02 amNot sure if anyone using Shimano have tried teh new 2021 new 12 speed Shimano Dura Ace C50 or C36. I prefer it better than my PCW 4540 or Hunt 44 with carbon spokes by a far stretch. Ride quality is good, new Shimano Dura Ace Hub is rock solid ....as good as Bora Ultra by ride feel/rolling. But wheelset ride is not as harsh as a 45/60 Bora Ultra
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
