I've got two sets of wheels, the Rapide CLX with a regular 11sp freehub and the Rapide CL with an XDR freehub. The CLX is a Ratchet EXP hub and the CL is a DT350. I want to swap the wheels between the bikes, with one being on 11sp and the other on AXS. In order to do so can I just switch the freehubs across them or would I need to buy new freehubs for each type of hub?
I guess the question is are the freehubs on these two models interchangeable? It's not entirely clear to me - thank you in advance!
Roval Rapide CL and CLX freehub inter-compatibility
You would need to get freehubs of each type - the Ratchet EXP isn't cross compatible with earlier 240, 350, 180 freehubs.
https://www.mtbr.com/threads/wtb-dt-swi ... positioned.
Ratchet EXP can not share with the old version freehub. the inside design are a little different.
