Lightweight Obermayer aerodynamics
petromyzon
by petromyzon
What do the Fernweg and Autobahn have to do with the Obermayer?
Aerodynamics does not suddenly kick in at 25mph.
mendiz
by mendiz
Ineos has not used Obermayer never.Always they are used Meilenstein 24 E tubular with the front wheel with 20 spokes.
You don´t stop riding when you get old, you get old when you stop riding.
spdntrxi
by spdntrxi
I've seen Obers with front 20..
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
eurostar
by eurostar
eurostar
by eurostar
mendiz
by mendiz
Show a pic, I asked LW and they confirm that os Meilenstein 24 E
spdntrxi wrote:
Tue Nov 16, 2021 10:23 pm
spdntrxi
by spdntrxi
not mine... I have 16 spoke genIV
I guess the center sticker could be faked?
2023 Pivot E-Vault
mendiz
by mendiz
Ah, ok, I wanted to say that Ineos always used only Meilenstein. About your pic, I saw in Instagram "lightwheelsrepair" ( a spanish man that repair LW) a pic where he shows a fake sticker Obermayer in hub of Meilenstein, the owner of that wheel did know it.
handler
by handler
So after plenty of thinking and some internet digging I’ve come a bit further on the topic. We’ve have some interesting insights on the topic. This analysis is only applicable to those who ride at 35 km/h and above (which could be during races) as it’s then the yaw angle drops toward +-5 degrees.
If we look at the analysis made by Jürgen Knupe and David Farmer at wing-light, both former F1 mechanical engineers, the result is unconventional to by todays standard, but still a result worth mentioning. They did conduct an analysis on six different wheelsets, Zipp 303, Campagnolo Bora, Lightweight, Zipp 808, Zipp 1080 and Zipp 900. The analysis is where done in ca 2010 (a bit unsure about the exact year, but the site give some hints it’s done during that period).
Without copy-pasting the whole analysis which can be found here http://www.wing-light.de/CFD/wheels.htm, let’s look at the chart below.
The chart shows the power which is needed to move the wheel through the air, also called the translational drag coefficient (cw) and the frontal area (A) of the wheel. Translational drag is just drag what we visualize it to be, the force acting on the wheel trying to slow it down and accounts for 75 % of the total drag, which the rest is due to rotational drag of the wheel. Rotational drag is the drag caused by the wheel rotating in another medium, highly affected by the viscosity of the medium and speed of rotation. Think about it as running a propeller in air or water. Rotational drag is why spoke nipples become interesting to hide, it’s like adding a piece of welded metal to a propeller in water, the rotational drag would jump.
Back to the chart! As we can see the drag is very similar to each wheel to yaw angles at 0-5 degrees at 40 km/h. Only at increased yaw angles we can notice a diverge in the lines. Both the Zipp 303 and the Campagnolo Bora wheel have decreasing efficiency in all yaw angles with a almost linear pattern. As expected, the Zipp 900 shows negative propulsion at extreme yaw angles, while the Zipp 808, Zipp 1080 and the Lightweight wheels does have increasing and then stabilizing drag in the more extreme yaw angles (which only accounts for a couple of percent of the total ride time, note from earlier posts in this topic). This part of the analysis does not account for the rotational drag, so what could have an impact is e.g. the spoke area and width or nipples. Please read further!
They provide us with an analysis accounting for the rotational drag which can be seen below and shows similar results, hence hinting about that the rotational drag is relatively less important, just what SwissSide reports. https://www.swissside.com/blogs/news/ro ... g-insights
The analysis completes the CFD analysis done by Knupe & Farmer with a wind tunnel test by German journal Velomotion. They are noting that their (Knupe & Farmer) analysis is resulting in lower drag numbers compared to the analysis made by Velomotion, although they criticize the use of forks used upside down for holding the wheel. Velomotion shows similar results as above, wheels are quite similar at lower yaw angles and only difference by a single digits watts. Hence, for any fast race with no strong crosswinds, most profiles above ca 40mm will be comparable good.
TL;DR
My conclusion is that cross wind speeds and expected race speed is more important when picking the right wheel for the race, as it’s when we have the unusual wind patterns as we see difference in wheel performance, otherwise almost all high profiles (>40 mm) as similar good. Including the old “V-shaped” Lightweight design. Tyre resistance and fit is not part of the analysis, which could affect the end results, just as the frame, the rider, and the surrounding riders (lots of dirty air in the peloton/group).
And as a final note, did you know that Swiss Side is (or was?) actually the aero consultants to Ineos? https://www.swissside.com/blogs/news/sw ... h-team-sky
petromyzon
by petromyzon
So they weren't too bad aerodynamically, if you ride fast, a decade ago. You still might find it hard to take advantage of the vast improvements in tyres over the past decade. And they cost 3-4x more than competing wheels, without being much lighter.
Is it just me or are they a product you buy just to show how much money you have?
handler
by handler
petromyzon wrote:
Mon Nov 29, 2021 12:42 pm
That's certainaly a point, but as for now, the fastest tested rubber is recently available for tubular.
https://r2-bike.com/VITTORIA-Tubular-Co ... full-black
https://www.bicyclerollingresistance.co ... 6&minpr=21
Although, we don't have the great allround tyre GP5000 available for consumers.
Trying not to make this a tubular vs other tyres topic.
The data shows that the passé is not blasé, we just need more objective wheel testing.
eurostar
by eurostar
Aerodynamics and weight are not the only factors. People also buy them (or bought them) for their durability. Some people use them for training as well as racing, which makes the cost easier to stomach. They're also low maintenance, because you can't true them.
RDY
by RDY
Jack65 wrote:
Tue Nov 02, 2021 4:57 pm
Just my 2 cents...
From all the data we have seen recently, the fastest design is used by Winpace Hyper based on aero hub and carbon spokes. In test done by Hambini their 50 mm wheels show 587 watts @ 50 km/h. Cheap chinese open mold wheels, Prime 50 mm, sold by Wiggle, 595 watts. His testing methodology is complicated and doesn't mean "real watts". How does it compare to watts at given speed?
Hambini has repeatedly said that he thinks the HyperX compare very well to other similar or greater depth wheels in his tests simply because they have a narrower rim than the others. Nothing to do with the hub, spokes or profile of the rim. Assuming a narrow tyre, narrow rims are faster - undoubtedly.
But if you're using modern wide '28' (really over 30) or 30s, or worse still 32s, the AR55 which the HX50s beat on 25s in his test, would most likely be comfortably faster because the tyre would mushroom less.
Prawn
by Prawn
Some interesting data and insights in this thread. It's hilly where I am, so most of the time I'm either climbing or wondering if I ought to pull the brakes on. Sure there are some flat sections where I'm trying to hold the bunch at 45+Kmh but that's a minor part of the average adventure. (I think that context is important, so that others can judge my views accordingly.) I've been down the 'modern / wide / tubeless' road, but in the end I found that a good old-fashioned set of Gipfelsturm tubular wheels were better in every respect. Why might this be a reasonable answer? I offer five observations: (1) There is nothing more aero than air! It is easy to be drawn in by low drag coefficients, but these need to be multiplied by frontal area to work out drag; wider may be better in some respects, but it is not a given. (2) In gusty cross-winds, forget about airflow staying attached; deep rims are going be a problem. (3) Wheel stiffness gives stability, imparting a sense of assurance in handling and in power transfer. (4) Less weight is good. (5) In terms of engineering, carbon fixed in a structure like a Lightweight Wheel is hard to beat. It is amusing when people talk about their 'modern' wheels (with holes drilled all the way through the rims, dis-similar metals in the nipples and spokes, and opportunities throughout the system for changes in tension, loss of stiffness, and noise. Some of the Lightweight wheel designs may seem dated, but they are still a long way ahead in engineering terms. Sure, I'd like a slightly wider rim; the benefits are not lost on me. Now, if anyone wants to part with a set of obermayers so that I can use them when there is no wind around then let me know!
rudye9mr
by rudye9mr
Not brand related but can help understand aerodynamics of the profiles and effect on steering...eye watering price as well...hope it helps in analysis..
