Hi all, I'm currently doing a retro-modern build of a Eddy Merckx 90's frameset I have found. The Staada OS.
It has a 9 speed Campagnolo Daytona groupset for the most part. I was going to hit up Ali for some relatively cheap carbon wheels as this will be a commuting bike, not a work of art. Any idea if it's possible to get these working?
They do mention 10/11 speed Campag freehubs but I have not clue if you can get this setup working.
https://www.aliexpress.com/item/32776764756.html
R13 hubs or novatecs.
Modern Carbon Wheels & Campag 9 Speed
Yes, no problem at all - Campagnolo 9-speed through 12-speed use the same style freehub body. Early 9-speed (which I don't think that the Daytona is) used a smaller lockring (26mm thread) instead of the later 27mm one, but that's pretty easy to sort (if you'd need it).
