Tubes on CLX64
Silly question maybe, but what tubes are best to run on these? Mine came with 26mm Turbo Cottons and I need to buy a couple of spare tubes. What length valve is preferred? Latex the way to go?
Thanks!
Thanks!
80mm valve.
Sent from my COL-L29 using Tapatalk
The rims have no bearing on which tubes are best.
Latex tubes are usually lighter than butyl, a little more supple, roll faster (the fastest tube possible), lose air overnight, and cost significantly more than butyl.
Another option is TPU tubes, which are lighter again, very durable, don't lose air over night. These are again more expensive than Latex, and roll faster than butyl but slower than latex.
Latex is the best choice for racing, while TPU makes for a great spare (small packing, very light), and also great for training rides (durable and don't lose air quickly.
Your Turbo Cotton tires are great racing tires. Not super puncture resistant but fast and supple. As they are non vulcanized, they benefit more from Latex, than vulcanized tires.
None of this however has anything to do with your specific wheels.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Thanks for your replies @MasterBean and @FlatlandClimber, that's very helpful.
seems like TPU with 80mm valves is the ticket for my general riding. Tubolito or similar.
After looking at options,TPU tubes with 80mm stems are not that common and are going to be hard to find locally. Are valve extenders a perfectly acceptable solution for using tubes with shorter valve stems?
Yes. Everyone uses valve extenders. For example there are also 80mm deep wheels and I don't know if a single tube that comes with valves long enough for those.steamroller wrote: ↑Wed Oct 13, 2021 4:08 amAfter looking at options,TPU tubes with 80mm stems are not that common and are going to be hard to find locally. Are valve extenders a perfectly acceptable solution for using tubes with shorter valve stems?
Awesome thanks. Am I better off getting tubes with removable valve stems and use extenders that fit in there? I think I've seen some that just go over the top of the whole valve as well but not sure how reliable that would be. Sorry for the newbie questions.
