Zipp 303Firecrest Disc vs Bontrager Aeolus Pro 37 disc
I can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- 40mm deep, 30mm wide externally, 25mm wide internally, 28c tire which will go uo to 30mm (give or take)
- around 1350gr
- €1750
Bontrager's 37 Pro:
- 37mm deep, 28mm wide externally, 21mm wide internally, 25c tire to be within the famous 105 rule.
- around 1500gr (considering already 50gr due to rhe thinner tires)
- €1250
Note: I'm not asking lightbycicle options or any other brand for that matter. Just focusing on these two, please. Thanks a lot!
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Isn't this a rather stark choice between hooked vs. hookless, max. 73psi and if you want to use 25mm tyres?pmprego wrote: ↑Sun Oct 10, 2021 10:35 pmI can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
303FCpmprego wrote:I can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Lighter
Durable
Resale
Crash replacement
I'm okay with 25 or 28c. I've never ridden 28c tires but it does seem to be the trend nowadays.Nickldn wrote: ↑Sun Oct 10, 2021 10:59 pmIsn't this a rather stark choice between hooked vs. hookless, max. 73psi and if you want to use 25mm tyres?pmprego wrote: ↑Sun Oct 10, 2021 10:35 pmI can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Lighter, yes, but that's why I also wrote their price.Ronin416 wrote: ↑Mon Oct 11, 2021 1:59 am303FCpmprego wrote:I can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Lighter
Durable
Resale
Crash replacement
In portugal (Europe) they do not offer crash replacement. They just offer lifetime defects replacement - both zipp and bontrager.
Seems like you’re already siding on the more inexpensive option.pmprego wrote:Lighter, yes, but that's why I also wrote their price.Ronin416 wrote: ↑Mon Oct 11, 2021 1:59 am303FCpmprego wrote:I can't decide which one to go. I ride tarmac 100% of the time. I DON'T want anything deeper given that my end goal is crosswinds stability and being light and responsive. I need them to be tubeless compatible (in Zipp’s case mandatory).
Quick spec recall.
Zipp’s 303fc:
- around 1350gr
- €1750
Bontrager's 37 Pro:
- €1250
Lighter
Durable
Resale
Crash replacement
Actually I'm not
I'm searching for an excuse not to go for the more expensive option. I've read a review from the bontrager saying they just deliver. Are not enthusiastic in nothing but for the price they are hard to criticize.
I was searching for someone saying "I've tried them both and i could not feel any difference"
I'm sure they are quite different wheels that take quite different tyres and provide quite a different ride feel.
As I mentioned above, I think you have to be sure if you want >=28mm tyres and <=73 psi, or 25mm tyres with >=85psi.
Work that out and you'll know which wheels are better for you.
I currently ride some low cost wheel that state to be 80psi maximum. I've always used 25mm on these and always at a maximum of 80psi (many time lower than that) so i guess I'm okay running low psi.Nickldn wrote: ↑Tue Oct 12, 2021 9:36 pmI'm sure they are quite different wheels that take quite different tyres and provide quite a different ride feel.
- wheelsONfire
I have no idea how Bontrager wheels feels (ride feel) and i can only tell how 303 Firecrest rim rides.
The first things you will notice are these
1. Road buzz is eliminated to a degree i have never experienced with any other wheelset.
2. Stable feel.
3. Not affected by crosswinds.
However the rim brake version have some other design.
It's a hooked design!
It is 19mm wide internally.
Rear wheel pre-taped 897g (Shimano/ Sram 11 speed freehub)
Front wheel pre-taped 713g
Tubeless valves 3g each
Tires slide on very easy, no tools needed!
The wheels are fitted with Vittoria Corsa G2 25mm
Tubolito innertubes
2. Stable feel.
Tubolito innertubes
Bikes:
Open *UP* (2016.04.14)
