What is considered the top of rim brake wheelsets now?
- wheelsONfire
Hello rim brake riders.
I would like to ask you guys at the forum, what is the best rim brake wheelsets available currently (might be a few, that i understand)?
Looking at something at 45-50mm rim depth. Not wims wider internally than 18-20mm.
Oh, i look them to be a "hooked" design, not hookless.
Mainly for 25mm tires, not larger.
Thanks!
Thanks!
Bikes:
Open *UP* (2016.04.14)
- Moderator
Agreed, Campy are now the go to for mechanical and rim brake
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
I have no doubt that the Campagnolo wheels are awesome but I'd buy a pair of Farsports wheels again in a second at 1/3rd to 1/2 the cost.
WTOs are expensive, but the ultra smooth hubs and bearings are stand out features.
For tubs they are probably the nicest feeling wheelset available. If I could replace my Easton EC90s tubulars it would be with WTO 60mm tubulars.
But the outer width of these wheels is only 26.5mm and although that is perfect for 25mm tubular tyres that run true to size, it is a bit too narrow for 25mm clinchers. Many 25mm clinchers run at 26mm+, so that 105% aero rule doesn't work with WTOs and most clinchers.
A true best in class clincher aero wheelset needs to be 27.5mm+ wide.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
Campy Bora WTO
Moots Vamoots RSL (2019)-Super Record 12
Cervelo S1 (2010)-Super Record 12
Kestrel RT700 (2008)-Dura Ace 9000
Mosaic GT-1 (2020)-SRAM Red viewtopic.php?f=10&t=174523
Lightbicycle do make 28mm and 30mm wide rim brake wheels, though I think the 30mm option might be too extreme for many frame-calliper combinations (I have the 28mm wide ones and with Dura Ace brakes they are at the absolute limit when the brake pads are new).
Yes, there are several. Take a few minutes to read-up on high end gear (Campy, Lightweight, Corima, etc).
Have no problem with later shimano gear matched with the correct shim levers
Have 6800 and 7000.
They work well.
I am not a weight weenie so don't know how they compare weight wise.
Reasonable cost and work well, so that's me sorted.
Have 6800 and 7000.
They work well.
- wheelsONfire
Corima wheels are 26mm max externally. I ordered a wheelset (not Corima), but it's not mentioned here. I'll see how they are.
I'm about to order a new fork to, to clear larger diameter tires.
Bikes:
- wheelsONfire
To expensive and to narrow....
I have Ax 38T at 1010g for a set if i want climbing wheels. Though they are tubular. Now i order only clincher wheels
Bikes:
Does WTO rim come in tubular format? Never seen any, neither does Campag website mention them.
