It’s time for my Giant TCR Advanced 1 disc (2021) to get a wheelset upgrade from the stock PR-2 (approx weight 2000g).
Given that I have decided for a budget around $1,500 AUD, I have set my mind on two options:
Option 1. Fulcrum Wind 40 ($1,600 AUD), 40mm deep carbon rims with standard steel bearings. Declared Weight: 1620g.
Option 2. Campagnolo Shamal ($1,700 AUD), 35mm front and 40mm rear deep carbon rims with cup and cone bearings. Declared weight: 1585g.
Alternatively stick with alloy rims, with the Fulcrum Racing Zero ($1,200 AUD), 30mm deep alloy rims with the USB ceramic bearings. Declared Weight: 1590g.
Now, I live in Melbourne (Aus) in a bit of a hilly area, but no major climbs. The rest of my rides are pretty flattish.
I am tempted towards the Wind 40, being a sort of affordable carbon wheelset, although not sure if performance wise they are worse than the Racing Zero due to them not having ceramic bearings than the latter? Also, the Wind 40 albeit being carbon are heavier than the Racing Zero.
I know none of these are "light" wheels, but this is all I can afford.
Any thoughts or suggestions?
Fulcrum Wind 40 vs Campagnolo Shamal carbon…or Fulcrum Racing Zero?
1st thought: since you're in Australia I'd take a good look at Caden wheels.
2nd thought: of your list I'd pick the Fulcrum 40s (with your described rides). Widest and deepest rims.
3rd thought: I have a set of Zonda wheels: really impressed by the hubs/bearing system.
If you ride often on shifty road surface, get Shamal for the wider int. width and thus bigger tire volume and lower pressure allowed.
