Thanks mate, your suggestion makes sense, I was more thinking of using 28mm during winter for my commutes to work, and swapping them out for 25mm for weekend longer rides.
Fulcrum Wind 40 vs Campagnolo Shamal carbon…or just Racing Zero?
Same here with a pair of Eurus. A month of rainy weather ruined the free hub bearings. Replaced with Phil bearings and no problem since.Moltobene wrote: ↑Tue Sep 14, 2021 8:36 pmHowever, I had to exchange the bearings of the freehub relatively quickly on both Fulcrum Quattros and the Zondas. They only used a seal on the outer side on both bearings. Apparently, water got in between the sleeve between both bearings and turned the grease in the freehub shell and the bearings bad. I'm hoping it'll be a long time before that happens again with some FAG bearings.
