NEW GP5000S TR
Forum rules
Both tyres mounted on 23mm ID Zipp 454 hookless rims:
25c measured 27.2mm
28c measured 30.5mm
25c measured 27.2mm
28c measured 30.5mm
IG: RhinosWorkshop
IG: RhinosWorkshop
Dittofruitfly wrote:I am in the 25 on the front (aero with my rims), and 28 on the back (easier to add compliance by tire choice than by frame design; and aero doesn't matter as much on rear wheel).
Roval CLX Rapide wheels
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
So a 35mm front rim and a 30mm rear rim - I'd say 28's would be the best option. The front should still be in the 105% rule with a rim that wide!
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
Has anybody racked up decent mileage yet on this rubber?
Yes. I binned this one today I hit a box cutter blade eight miles from home at the beginning of my ride. A Good Samaritan gave me a ride home. This is my first un-sealable tubeless puncture. The good news is that this tire is very easy to mount. Once I got home I quickly mounted a new one and managed to still get a ride in for the day. The damaged tire was very easy to come off and the new one went on with the help of a tire lever (I use levers because it's so much faster and it saves my thumbs)DieselCondor wrote: ↑Mon Dec 06, 2021 11:07 pmHas anybody racked up decent mileage yet on this rubber?
Wow, That's a proper slash! Don't think any road tyre would of survived that.
Thankfully the blade stayed away from your rim! Good to hear about the easy fit of the tyres- what size have you been using?
Good to know. If only you get find a set of 30's or 32's around...in transparent in the US. Found some in black...but want to get the transparent versions.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Everywhwere I have looked the transparant seem to be out of stock until mid Febuary.
The transparant do look nice but judging from this thread they are a little heavier than the black versions.
Thanks for the sizing feedback. I will grab some 25/28 black when they become available in the UK at non mental prices
- IrrelevantD
Where'd you find a black 30? Everywhere I've seen is sold out.
Black 32s available in the UK (from me), if anyone needs a pair.
IG: RhinosWorkshop
IG: RhinosWorkshop
