Forum rules
TobinHatesYou
by TobinHatesYou on Mon Aug 01, 2022 5:00 am
manystyles wrote: ↑Sun Jul 31, 2022 5:28 pm
Mocs123 wrote:My guess is that all tubeless "tan wall" tires have painted sidewalls.
I don’t think any of the Rene Herse tires have painted sidewalls.
They obviously do because they come in three different colored sidewalls???
skom25
by skom25 on Mon Aug 01, 2022 6:01 am
52 pages is little too much to check.
Has someone measured real width of 32c on rim with internal diameter around 23 mm?
dgdracing
by dgdracing on Fri Aug 05, 2022 3:54 pm
What is the remaining tread looking like? I was expecting reduced mileage due to the significant weight reduction. The TL did 6.500km last year, after which they really where "done".
pdlpsher1
by pdlpsher1 on Fri Aug 05, 2022 6:50 pm
scapewalker wrote: ↑Fri Aug 05, 2022 1:30 pm
Just had what looks like a material defect on my 5000S TR tire after ~4000km.
It's not unusual. It's a thin spot in the tread. I just tossed out a tire that got a small cut that was plugged with a Dynaplug. I took the tire off and was going to patch the cut from the inside. Then I found a small bald spot unrelated to the cut, one that looks just like yours. The tire has already worn down past the TWI so I've already gotten my money's worth. I decided it's not worth it to put more miles on a tire with a small bald spot. Hence I tossed the tire in the bin.
Is your tire already worn past the TWI? If so then I wouldn't necessarily call it a 'defect'.
kode54
by kode54 on Fri Aug 05, 2022 7:40 pm
Looks similar wear to an area on a tire that I had to lock up...thus, wearing out one area more than the surrounding center track. It was that or T-bone a car that pulled out in front of me and decided to stay there...right in front of me. Either go or get out of the way!
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
scapewalker
by scapewalker on Fri Aug 05, 2022 10:56 pm
pdlpsher1 wrote: ↑Fri Aug 05, 2022 6:50 pm
Just checked and it's indeed worn past the TWI. It's the back tire obviously but i'm still surprised/disappointed with the lifespan of these tires. Got more out mileage out of turbo cottons i used before.
These were supposed to be a good compromise of speed and durability or so i thought.
Edit: Can't recall a single lock up on these tires. Front tire looks decent still.
pdlpsher1
by pdlpsher1 on Sat Aug 06, 2022 12:46 am
TobinHatesYou wrote:I mean, I got 3700mi out of a 25mm GP5K S TR. I don't think I would get 7400mi out of a GP5K TL.
3,700 miles only as a rear tire? On the front my tires last for years if I don't rotate them.
Sent from my KFMAWI using Tapatalk
TobinHatesYou
by TobinHatesYou on Sat Aug 06, 2022 2:37 am
pdlpsher1 wrote: ↑Sat Aug 06, 2022 12:46 am
Rear tire. My GP5K TLs always had sidewall tears and never lasted 3700mi. The only rear tire I’ve had that lasted longer was a Corsa Control 30mm and that’s cheating because the contact patch is greater.
kode54
by kode54 on Sun Aug 07, 2022 10:29 am
pdlpsher1 wrote:Yup. The old TL outlasts the S TR by a factor of two. It's a way for Conti to sell more tires.
Conti would sell more if availability was better.
- Factor LS Disc
