TBH the fairest comparison would be to seal the tubeless tire and remove all extra liquid sealant. The liquid sealant is providing puncture/flat protection… something the latex inner tube doesn’t do.
NEW GP5000S TR
Forum rules
- ultimobici
- in the industry
- Contact:
How so? Mine have been fine since day one.TobinHatesYou wrote: Veloflex tubeless are downright scary.
Yup, I run the Veloflex Corsa Race TLR as well as Evo TLR on my bikes. I love them for their extraordinary grip and comfort level. Super easy to mount.
They both loose around 0.2 bar per day, which I find very acceptable. They do not sweat (I believe this is what TobinHatesYou is referring to) although they're very light (all of the ones I have, come within 10 grams of their advertized weight). A friend who also uses them says his tyres absorb some of the initial sealant on first installation, but this is not my experience (using regular Orange Seal).
I've not had a flat in around 5k km combined mileage, just 1 small superficial cut in the sidewall incurred on a gravel climb while bike packing in southern France last month. For sure a set will not last 5k km but their price is also lower than other premium TLR tyres.
I much prefer them to the GP5000S TR although they have tested a bit slower on BRR.
BRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
Last edited by FlatlandClimber on Sat Aug 13, 2022 8:57 am, edited 1 time in total.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
To me it's highly likely it's down to Continental fiddling with the compound or manufacturing process since they last tested the black version last year, as we've seen quite a few differences in the pattern on the inside of the tyre...
Cannondale SSEvo3 'Atticus' - 7.2kg
viewtopic.php?f=10&t=161634
Cannondale Systemsix ’Dante’ - 7.7kg
viewtopic.php?f=10&t=167144
ultimobici wrote: ↑Fri Aug 12, 2022 7:03 amHow so? Mine have been fine since day one.TobinHatesYou wrote: Veloflex tubeless are downright scary.
At least over here, the sidewalls get torn to shreds near the end of the tread cap. Additionally they don't have sufficient abrasion protection at the bead and some carbon rim hooks will shred the casing.
My Corsas looked ragged after 900km.
yes it does.. I'm riding them too.FlatlandClimber wrote: ↑Fri Aug 12, 2022 8:01 pmBRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
https://www.bicyclerollingresistance.co ... ransparentFlatlandClimber wrote: ↑Fri Aug 12, 2022 8:01 pmBRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
Puncture score and wet grip result is better though.
I know this may not be financially feasible but a true scientific test involves testing more than just a single sample. I wouldn't take this seriously since Jarno tested a single black tire vs. a single tan tire.FlatlandClimber wrote: ↑Fri Aug 12, 2022 8:01 pmBRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
Tan wall of latest generation loses 1-2W, but instantly getting it back on aerodynamics, because 28mm tire is around 2mm narrow than previous S TR which was almost 30mm on my wheels.warthog101 wrote:https://www.bicyclerollingresistance.co ... ransparentFlatlandClimber wrote: ↑Fri Aug 12, 2022 8:01 pmBRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
Perhaps those 1-2w are actually just the extra RR you get from a wider tyre then?req110 wrote: ↑Mon Aug 15, 2022 8:13 amTan wall of latest generation loses 1-2W, but instantly getting it back on aerodynamics, because 28mm tire is around 2mm narrow than previous S TR which was almost 30mm on my wheels.warthog101 wrote:https://www.bicyclerollingresistance.co ... ransparentFlatlandClimber wrote: ↑Fri Aug 12, 2022 8:01 pmBRR just tested the tan STR and it's significantly slower. If that's real, that sucks.
No, New/slower are narrower.
Older/faster are wider
But difference is only about 1mm as per my latest measurement.
