NEW GP5000S TR
Forum rules
sfo423
by sfo423
bobones wrote:
Wed Nov 10, 2021 6:55 pm
sfo423 wrote:
Wed Nov 10, 2021 6:32 pm
Can anyone comment if they are easier to install (tubeless) than the prior gen gp5000 tl?
The STRs are pretty damned tight when new too, but this time around I managed with one of these. The main thing for me is that the STRs loosen up considerably after initial mounting, and I can reinstall them without any tools, which can matter for on the road repairs.
What tire is the STR? Roadside repair (i.e. the actual ability to make one) capable tire is high on my tubeless list. The pro one tle is easier than the old gp500 tl (on a Fulcrum speed 40 db).
bobones
by bobones
sfo423 wrote:
Wed Nov 10, 2021 7:31 pm
Seriously? What's the subject of this thread?
warthog101
by warthog101
I thought the TLs were nigh on impossible to install and sent them back. The STRs are pretty damned tight when new too, but this time around I managed with one of these. If I had this tool for the TLs, I may have succeeded with those too. The main thing for me is that the STRs loosen up considerably after initial mounting, and I can reinstall them without any tools, which can matter for on the road repairs.
I have only one set of wheels the TLs mount on.
Prime rr50 v3.
I have read multiple reports of them being difficult to fit.
They just aren't on my wheels.
They go on by hand.
Seat with a std track pump too.
Pretty disappointed they are discontinued tbh.
warthog101
by warthog101
kode54 wrote:I ran both tubed and tubeless (TL)...still had more punctures than previous versions of Contis. I'm hoping the 5000S TR will be my next tire.
50+k km on GP4k
Only about 10k km on 5kTL.
Never had to stop and repair a puncture on the TLs.
As I said, the 2 bits of wire in the rear TL would have been 2 punctures and a stop and replace the tube on the 4k.
Running latex sealant in the tyre is a huge advantage over just a tube and the tyre seems to have a strong carcass.
sfo423
by sfo423
Ha!
S TR (not str)
Got it.
bobones wrote:
Wed Nov 10, 2021 8:13 pm
RDY
by RDY
Received a pair of 28mm brown wall. No in use feedback as they'll wait for a new road wheel set, and will most likely run 28mm front and 30mm rear.
Aesthetically, they look hideous. If you're hoping for something that looks like a normal tan / gum / butterscotch wall tyre, you're out of luck. The thinly painted narrow band of brown ink / paint looks really cheap and nasty.
ryanw
by ryanw
Shall get the scales out and weigh this lot.
IG: RhinosWorkshop
kode54
by kode54
RDY wrote:
Thu Nov 11, 2021 11:06 am
That's disappointing regarding the color. I like the tan sidewall color of the Schwalbe Pro Ones....its more darker/warm brownish tan than some of the others.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
ryanw
by ryanw
Weighed 2 of the 20 I have in. Both coming in under manufacturers claimed weight (250g / 25c).
Compared to the tan 25s, they're about 30g less across the two tyres.
IG: RhinosWorkshop
pdlpsher1
by pdlpsher1
ryanw wrote:
Thu Nov 11, 2021 11:43 pm
Wow. That's nice. I wonder why the tan wall is heavier. It makes no sense.
The back of your 25s look a bit different from the back of my 32s. I don't have a honeycomb-like pattern as seen in your pic. Do you mind posting a pic of the back? Did Conti just changed something to make it lighter?
I'm very impressed with the S TRs. I have bought a bunch of the old TLs just before the S TRs announcement. I'm selling my new TLs at a loss because I want to run the S TRs from this point forward.
windscreen
by windscreen
Aryeh wrote:My pair of 28mm transparent tires ...
They definitely were not easy to mount on my Light Bicycle WR50 rims but not terribly difficult either. I could've used a 3rd hand.
The exact setup I'm planning to run. If you have a calipers, would you mind measuring your mounted width and let us know what pressure you're running. Thanks!
-Steve
Sent from my Pixel 5 using Tapatalk
Aryeh
by Aryeh
-Steve
31.6mm at 65psi
ryanw
by ryanw
Pic of inside.
IG: RhinosWorkshop
justRideIt
by justRideIt
Slowly coming into stock at German retailers and coming down from initial recommended retail price of 79€.
Example: in stock at bike24 for 69,90€
https://www.bike24.de/p1530145.html
I'll wait for spring though... can already see me going through the whole tubeless setup ritual.
Only to forget about the roadbike for a couple of months and return to two flat tires with dried out sealant at the bottom 😂
2020 S-Works Tarmac SL6 Disc @ 6.35-ish kg: viewtopic.php?f=10&t=159454
2021 Specialized Diverge viewtopic.php?f=10&t=165482
ryanw
by ryanw
Just fitted a pair of 25s to Zipp 454s (B1) and did all by hand. Really impressive for a Conti!
IG: RhinosWorkshop
