NEW GP5000S TR
Forum rules
allrandomletters
by allrandomletters
Anyone know what size the 30s are when mounted on 25mm internal rim?
pdlpsher1
by pdlpsher1
ryanw wrote:Pic of inside.
Thanks. That looks as smooth as the non-TL and smoother than my 32s. Perhaps Conti changed something after seeing the third party test results Image
IrrelevantD
by IrrelevantD
allrandomletters wrote:
Fri Nov 12, 2021 4:06 pm
based on my experience with a 28 TL on a 24mm internal rim... I'd guess 33mm give or take 1mm. My 28 TL measured 30.5 on a 24. I'm trying to find a 30 S TR but not having much luck yet.
aeroisnteverything
by aeroisnteverything
So... apart from weight, dimensions and installation: what do folks think of these in real life usage, particularly after putting on some miles? How is air retention? How is the ride/feel (vs previous GP5000 TL or clincher)? Any puncture experiences worth noting?
pdlpsher1
by pdlpsher1
Nothing negative to note except for slightly less air retention. I’m using less sealant than before (30ml vs 60ml) so it may not be entirely the tire’s fault. The TL loses 2psi a day vs about 4psi that I’m seeing now.
I dropped my pressure by 3psi (55 to 52) and it’s still fast by feeling. The ride quality is superb at 55psi but now at 52psi I’m in heaven. I feel like this tire really excels at rough pavements when run at a low pressure. If you’re currently on the TLs and planning to get the S TR I suggest upsizing to a larger size. With the S TR there isn’t a huge weight penalty with the larger sizes.
One notable positive that hasn’t been mentioned thus far is the lack of strings forming by the tire bead. This is a problem on the TLs (but strangely not on the non-TLs). I’ll keep an eye on this as I accumulate more miles.
kevinw
by kevinw
pdlpsher1 wrote:
Sun Nov 21, 2021 5:12 pm
I hate those strings!!!
MXM
by MXM
Has anyone tested the 25c or 28c on a Giant SLR 1 with 19 mm inner rim width (23 mm outer width)? I am trying to determine what size these will be when mounted. Thanks!
tunaseng
by tunaseng
MXM wrote:
Mon Nov 22, 2021 10:49 pm
Interested to know this as well. Can we even fit 28c onto 19mm inner rim width?
TobinHatesYou
by TobinHatesYou
tunaseng wrote:
Tue Nov 23, 2021 6:49 am
Of course.
IrrelevantD
by IrrelevantD
I don't see why not, we used to run MTB tires on 17mm rims not terribly long ago. It's no longer concidered optimal, but it's not going to be unsafe.
Ritsuke
by Ritsuke
What size would you guys advice for a road bike, rider weight 70kg, Tarmac SL7? I'm in doubt between the 25mm or 28mm and no idea what could make me chose for one or the other.
Road // 2023 S-Works Tarmac SL8 | Shimano Dura-Ace Di2 | Roval Rapide CLX
Gravel // 2023 Specialized Crux Pro | SRAM Force AXS | Roval Terra CL
Retired // 2022 S-Works Shiv TT // 2021 S-Works Tarmac SL7 // 2019 Specialized Allez Sprint Red Hook
Mocs123
by Mocs123
What's the width of your wheels? That would probably decide for me. I even have one bike that I run a 25mm in the front and a 28mm in the rear.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
Nickldn
by Nickldn
I think it's about whether you value comfort, or speed and how bad your roads are.
On a Grand Tour stage winning bike like the SL7 25mm tyres will be more 'racy', but 28mm may be more comfortable if that's what you need.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
fruitfly
by fruitfly
I am in the 25 on the front (aero with my rims), and 28 on the back (easier to add compliance by tire choice than by frame design; and aero doesn't matter as much on rear wheel).
Factor Ostro
