Forum rules
C36
by C36 on Sat Jul 16, 2022 8:41 am
MagicShite wrote:
Isn't that with 20ml sealant?
It's going to be quite different with a standard 80ml sealant no?
It is tested with 20ml, that’s probably too little to be representative, 30ml seems to be the minimum recommended for 23mm tires and 60 for 28mm (directly from orange seal)
Aerocoach did test impact of sealant, 60ml is 2.5W slower than the 20ml from BRR test.
Supersix evo2 HM - 5.9 stiff-aero version, 5.6kg light specs.
C36 on Sat Jul 16, 2022 8:41 am, edited 3 times in total.
pmprego
by pmprego on Sat Jul 16, 2022 8:53 am
I put 400ml in each tire. I love the feeling of liquid going around my tires.
Oh people... I get some don't like tubeless. Not everyone has to like. But saying stuff like that is just senseless.
(I'm joking of course - on new tires around 50-60ml for initial seal and then no more than 30ml each refill - I remove "old" with a syringe to make sure of the quantities)
pmprego on Sat Jul 16, 2022 9:30 am, edited 1 time in total.
TobinHatesYou
by TobinHatesYou on Sat Jul 16, 2022 9:00 am
I put 40mL in a new 25mm tire because some of it will work toward the initial seal. I put 60mL in a 35mm tire.
Orange Seal vaguely recommends 1-2oz (roughly 30-60mL) for "road."
Stan's NoTubes recommends 2oz (60mL) for 700x40mm tires.
C36
by C36 on Sat Jul 16, 2022 10:00 am
TobinHatesYou wrote:
Orange Seal vaguely recommends 1-2oz (roughly 30-60mL) for "road.".
Asking Orange seal customer service they recommend “after first injection” to keep 30ml on 23mm, 45 on 25 and 60ml on 28mm tires to “maximise performance and sealant-capacity lifespan”
MagicShite
by MagicShite on Sat Jul 16, 2022 11:29 am
C36 wrote: ↑Sat Jul 16, 2022 8:41 am
Thanks for the source. I totally forgot where I read them and I can't be arsed to google it up again.
But yeah, 60ml has a 2.5w gap that will go beyond the gap between Tubeless vs Latex.
I'm definitely not running anything lower than 50ml from where I'm from. It's hot and humid here.
pmprego
by pmprego on Sat Jul 16, 2022 11:35 am
Those graphs are very very nice but I wonder whats the confidence interval of these numbers. I just wish they would disclaim that. The fact they don't do it suggests that they are really not "good looking numbers".
Roadbiker10
by Roadbiker10 on Sat Jul 16, 2022 4:19 pm
I don't understand. I'm not talking about running tubeless at all. Just how the S TR with just latex tubes inside would compare to regular GP5000 non tubeless with latex tubes.
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Mocs123
by Mocs123 on Sun Jul 24, 2022 11:02 pm
OK, I got my first tubeless flat the other day 48km into a 105km ride, I hit a pothole and got a small puncture in the sidewall. It had been 80 days since I had topped off my sealant, and obviously that was too long as it was dry and I had to pop in a tube to get home. Ironically though it took me an hour and lots of blood, sweat, and tears to get the tires mounted originally but this time they went on by hand -no problems at all. I had wondered if I'd ever be able to get the tire back on the rim after having to put a tube in on the side of the road, but it was no problem. I got home and put sealant in and it seems to be holding air after an initial bubble or two.
What are your thoughts - is this tire toast or am I ok? Or should I try and patch from the inside. Front tire 3500km on them, 80psi, 80km rider.
https://imgur.com/dnOHpx2
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
jlok
by jlok on Mon Jul 25, 2022 2:12 am
I'd probably feel safer by patching it from inside. Not sure how much it helps tho.
warthog101
by warthog101 on Mon Jul 25, 2022 2:17 am
Patch and on the rear not the front.
Safest would be to bin it.
I'd rather spend the money on a consumable like a tyre than risk a crash due to sudden failure.
I expect if you asked the manufacturer they'd say bin it, there appears carcass damage.
Mocs123
by Mocs123 on Mon Jul 25, 2022 12:29 pm
Well I ordered a new tire - Actually I ordrered two as I wanted to go tan wall on that bike. That was an expensive pothole but at least I found them on sale.
kode54
by kode54 on Mon Jul 25, 2022 8:36 pm
Mocs123 wrote: ↑Sun Jul 24, 2022 11:02 pm
Maybe try one of these before tossing it out....
https://bikerumor.com/lezyne-2022-eurob ... new-pumps/
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
pdlpsher1
by pdlpsher1 on Tue Jul 26, 2022 5:24 am
Mocs123 wrote: ↑Mon Jul 25, 2022 12:29 pm
Your setup seems to have a narrow tire mounted on a wide rim. This is good for aero but not good for sidewall protection. If you run a wider tire on the same rim the sidewall will be more protected by the tread.
Mocs123
by Mocs123 on Wed Jul 27, 2022 9:15 pm
I recieved my two tanwall 25cx700 GP5000S-TR's today. 254g and 257g with the bands on (but paper removed). I think my black versions were 249g and 250g if I remember correctly. These are my first "tan wall" tires and it appears the "tan" color is a bronzy color almost painted on.
