NEW GP5000S TR
Forum rules
I wouldn't bother with TLs. They are a pain in the ass to mount on almost every rim I've tried.
TLs are great.
If I could still get 'em I would.
Just mounted by second set of 28c TLs tubeless on Rapide CLX (v1 "non tubeless") wheels with the original pre-installed "tubeless but nor really tubeless" tape and in each instance the tires went on super easy and set up on the first try (with compressor). I have S TRs waiting to go on but the TLs just last forever so will be a while I think.TobinHatesYou wrote: ↑Wed May 18, 2022 12:11 amI wouldn't bother with TLs. They are a pain in the ass to mount on almost every rim I've tried.
EVO1 | 5.37kg
EVO3 (sold) | 6.51kg
EVO4 | build thread coming soon
S5 Disc
SystemSix (sold) | 8.01kg
P5 Disc | heavy but fast
S5 Disc
Recently mounted TLs and S-TRs.
The new S-TR tires are so much easier to mount. They are almost as easy as GP5000 clinchers. No lever required in my case.
Keen to get peoples thoughts on this: I had to use a ‘bacon strip’ out on a ride today after riding over a chunky bit of glass, the sealant wasn’t quite doing the trick. It worked well and I got through another 2 hours of riding happily.
Do I:
A) leave it as-is and just top up the sealant?
B) clean the tire and apply a tubeless tire repair ‘patch’?
C) bin it and buy a new one?
Do I:
qickslvr2 wrote: ↑Tue May 24, 2022 8:39 pmKeen to get peoples thoughts on this: I had to use a ‘bacon strip’ out on a ride today after riding over a chunky bit of glass, the sealant wasn’t quite doing the trick. It worked well and I got through another 2 hours of riding happily.
Do I:
Bacon strips can eject at high pressures, though maybe if you ride at lower pressures for a while and allow the sealant to "cure" around the plug, it might become more permanent.
I have a DynaPlug in the side of my GP5K S TR right above the bead. I have ridden this tire at 105psi to test the security of the repair. It has held up for a few weeks without issue. The tip seems to do a good job of helping keep the plug from wiggling out.
I just tried on my Roval Rapide CL and it was a pain compared to the "old" GP5000 clinchers so it depends quite a lot on the wheels. I didn't try the front one but suspect that would be even worse. Happy that I never tried the TL version if it's worseopenwheelracing wrote: ↑Sat May 21, 2022 11:28 pmRecently mounted TLs and S-TRs.
TL version was a full on battle. I fitted the S to a Rapide today just with thumbs, that's a first for me with a tubeless tyreSace wrote: ↑Tue May 31, 2022 7:31 pmI just tried on my Roval Rapide CL and it was a pain compared to the "old" GP5000 clinchers so it depends quite a lot on the wheels. I didn't try the front one but suspect that would be even worse. Happy that I never tried the TL version if it's worseopenwheelracing wrote: ↑Sat May 21, 2022 11:28 pmRecently mounted TLs and S-TRs.
https://www.youtube.com/watch?v=JA716I- ... yclingTips
1min 48s. is that a GP5000 Tub ? appear again in 2min03s
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
After months and months...5000S TR still difficult to buy...and if you find them, full price at the very least! What's up with that?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Not interested at that price and Contis are my favourite tyre.kode54 wrote:After months and months...5000S TR still difficult to buy...and if you find them, full price at the very least! What's up with that?
Not paying $140 for a consumable like a bicycle tyre.
