NEW GP5000S TR
Forum rules
It must depend on the tire case/tread thickness and pressures used because even a thicker bacon strip worked its way out of a center puncture on my Pro One TT tire. I had left puncture facing down at about 85psi in my garage while I worked on another bike. All of a sudden I hear a loud PSSSHSHHRRRR 40 minutes later and the plug had shot out along with all of the Orange Seal.
And yep, I gave the tool a twist before pulling it out.
Maybe. Guess I'll keep the Dynaplug kit with the road bike and the GI kits with my gravel and mountain bikes.TobinHatesYou wrote:It must depend on the tire case/tread thickness and pressures used because even a thicker bacon strip worked its way out of a center puncture on my Pro One TT tire. I had left puncture facing down at about 85psi in my garage while I worked on another bike. All of a sudden I hear a loud PSSSHSHHRRRR 40 minutes later and the plug had shot out along with all of the Orange Seal.
You might have answered this but how hard to mount? I am looking at putting them on my CL50's.ryanw wrote: ↑Fri Oct 15, 2021 11:28 amFirst ride this morning (had man flu).
Hated GP5000TL, always loved corespun casing tyres due to superior feel and grip.
Think these shall be my go to tyre. 700x28 come out at 29.2mm on 21ID Rovals. 275g on the nose.
Ran 72R/62.5F. Very comfy, not like riding on hose pipes. Felt spritely and rolled beautifully.
They shall be staying on my SL7 until the tan model arrives
I am running Turbo Cotton's presently but have always, in the past, run C5000's when I ran clinchers.
Not super easy on Rapides, but both beads went on with a tyre lever without too much trouble.
IG: RhinosWorkshop
IG: RhinosWorkshop
Aerocoach posted on IG that results are due this week.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Saw that from aerocoach, they also test the black sidewall version. Do you think there is any difference to the brown / unpainted version?
I had a problematic pro one that had a glass cut that I couldn't keep the worms in. So I fashioned a strip of inner tube got that in there halfway or so, put a dab of super glue on the tire which incorporated into the two piece going in stuck that in, but that set up a bit put the glue section into the interface of the cut. Then I pulled it out.. I turn the tool that an angle and put my thumb on that area holding it down.TobinHatesYou wrote: ↑Sat Oct 16, 2021 12:16 amIt must depend on the tire case/tread thickness and pressures used because even a thicker bacon strip worked its way out of a center puncture on my Pro One TT tire. I had left puncture facing down at about 85psi in my garage while I worked on another bike. All of a sudden I hear a loud PSSSHSHHRRRR 40 minutes later and the plug had shot out along with all of the Orange Seal.
that tire is running fine to this day and holds here as good as any I've had tubeless.
Edit to say.. that cut was not running on the center of the tire. Does not meet where the tire contacts the road.
I believe almost nothing I read and 'hear'
I believe roughly half of what I see with my own eyes.. in person.
I do not carbon.. anything
Quite underwhelming.
I'll stick to Turbo Cotton for Road racing.
I don't think it's underwhelming.
On 25mm the new ones are 1W faster.
You have to also keep in mind, that new ones are like 40g lighter and have higher TPI with potential of better grip and feel.
What i am surprised is that GP5000 clincher are same fast as GP5k S TR... I am wondering what kind of inner tube they are using.
The result of Turbo Cotton is fine, but me and my friends don't have a good experience with turbo cotton and poor reliability.
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
Aerocoach tests clinchers with latex. So the result that the new TR tyre is the same is not surprising - it's how it should be. Franky as between BRR and Aerocoach, the discrepancies can all be explained by testing measurement errors + tyre batch variance, so I would not die on a hill defending the propositon that Turbo Cotton really is faster than Conti (or vice versa) or that there really has been that 1w improvement between the TL and the TLR version.req110 wrote: ↑Tue Oct 19, 2021 4:49 pmI don't think it's underwhelming.
Broadly the picture remains thus: Conti 5000 in its clincher and tubeless guises was and remains the fastest tyre availabe that you can sensibly ride every day. The tubeless has been improved in installation ease and weight so it will become the right choice for more people. Performance is largely the same as it was.
Marketing push - they did an incredible job of generating buzz to the point where we were all expecting miracles.
Nonetheless they've taken the market-leading tyre, made the tubeless version as fast as the clincher w/latex, broadened the compatibility to all modern wheels, chopped 50g off the weight, got rid of an outlier size and added the more useful 30mm, got rid of a load of SKUs with the clincher version, added the tan wall in all sizes and allegedly improved the road feel. It's the fastest non-TT tyre, although Turbo Cotton fans could argue the point.
I'm not sure what else they have to do?
If aerocoach tests the S TR with a latex tube:
does anyone have an idea what the rolling resistance would be in a tubeless Setup with say 30ml sealant?
2020 S-Works Tarmac SL6 Disc @ 6.35-ish kg: viewtopic.php?f=10&t=159454
2021 Specialized Diverge viewtopic.php?f=10&t=165482
