That's the problem... you've hogged all the supply.
NEW GP5000S TR
Forum rules
Long term reviewKurt1980 wrote: ↑Tue Feb 15, 2022 4:03 amCan confirm after about 20 hours of inflation the following:
1. 25mm GP 5000s TR tyres
2. Mounted to I:19mm, E:26mm Farsports rims (actually measured at 26.3mm)
3. Inflated to 25.45mm @80 psi with 60mL of Stan's sealant
I'll do another check in a few days time to see if there's any significant change. Will post if there is.
Kurt
Use:
About 4000km.
Have used these on smooth roads, chip seal, dodgy roads with broken glass, a tiny bit of gravel, and my resistance trainer.
Current Condition:
Tread is still ok - decent life left in the amount of grip, but a quite a few nicks and cuts present.
Width is between 25.65 and 25.9mm.
Got a pretty nasty slice on the shoulder of the tread that Stan's couldn't seal past 40psi, but Orange Seal seems to be able to.
Grip is as per new. Caveat: I rarely slide out on road bikes, so I don't think I'm close to pushing grip to the limit.
Summary:
Durability is good, tread is a bit vulnerable but hasn't actually failed yet.
Grip is still as new.
Price is a bit much at times, although specials can be found.
Availability is not great, but that's a sign of the times, really.
For those of us with 26mm rims and who want to be 105 rule compliant, these fit the bill.
I would prefer a bit more weight to increase the durability/minimise the cuts.
Until someone makes or points me toward a better tyre (per my parameters), then this will be my tyre of choice.
Ridley Helium SLX - RIP https://weightweenies.starbike.com/for ... lit=ridley
Scott Foil - current viewtopic.php?f=10&t=173046&p=1813155#p1813155
Mine after 1500km also have quite a few nicks and cuts. This is just the front wheel:
I went on a gravel path once.
Nicks/cuts are pretty random. I ride in an urban environment and have some, but no more or fewer than other tires.
I wonder if you can fill in the nicks with ShoeGoo or use Crazy Glue to close up the gap. My older GP4000SII had similar nicks on crappy NJ roads.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
https://twitter.com/vinssout/status/154 ... 24/photo/1
Some chat on Twitter about a 210g TT version - not sure if this will show up in any of the TDF Time Trial tech galleries.....
It was already on team ineos bikes.petromyzon wrote: ↑Fri Jul 01, 2022 6:07 pmhttps://twitter.com/vinssout/status/154 ... 24/photo/1
Kind of exciting! Should dethrone Corsa Speed as the fastest road tyre.pmprego wrote: ↑Fri Jul 01, 2022 7:42 pmIt was already on team ineos bikes.petromyzon wrote: ↑Fri Jul 01, 2022 6:07 pmhttps://twitter.com/vinssout/status/154 ... 24/photo/1
- Factor OSTRO VAM
- Cinelli STRATOFASTER
I just requested it on BRR, hope it's fast!
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Guessing it’s the exact same casing with a 1.8mm total thickness at the center tread?
- robbosmans
- Moderator
- Contact:
Ganna got 2 punctures in training so it will be TT only I think.
