NEW GP5000S TR
Forum rules
http://www.cyclesetforme.fr/essai-roule ... 5000-s-tr/
Alban Lorenzini first to publish data. My French isn't great but I think he says the tyre is ballpark 10% faster than GP5000TL and, with a tube in, would be ~0.5W faster than GP5000 at 30kph.
Not life changing but as a like for like replacment for the old tyre a pretty substantial difference. This sort of advantage would be quite difficult to ignore if you are a high level rider not on Conti IMHO.
I know I can't feel .5W. I just bought a GP5000TL for $39 to get me through the winter. I'll get the newer tire when I see it on sale in the spring.
petromyzon wrote: ↑Sun Oct 10, 2021 5:13 pmhttp://www.cyclesetforme.fr/essai-roule ... 5000-s-tr/
He's testing by actually riding on rollers, which isn't great.
30km/h is also considerably slower than any race or group ride around here. I'll wait for BRR or Aerocoach's test as either should show the GP5KS TR on par with the Corsa Speed.
Not exactly, that's the opposite. He's saying first that 5000TL is 0.5W faster that 5000STR. But this difference is revealed with panaracer R'air tubes and that's not the way this tyre has to be used since it's a tubeless (ready) tyre.petromyzon wrote: ↑Sun Oct 10, 2021 5:13 pmhttp://www.cyclesetforme.fr/essai-roule ... 5000-s-tr/
Below, he's comparing 5000STR with 5000+vittoria latex tubes (since BRR is saying 5000+latex tubes is pretty equivalent at 0.1W to 5000TL) and it's 6.6W faster on rollers (that means 1W on the road, for him).
He estimates that it's not 20% faster claimed by continental but more realisticly 10%, waiting for more precise data.
Yep, been told potentially even early 2023 for us in the UK.
Black should be here next week.
IG: RhinosWorkshop
IG: RhinosWorkshop
No doubt but my GP5k TL tyres were 26mm when new so hopefully there is some improvement.TobinHatesYou wrote: ↑Sat Oct 09, 2021 8:45 am
25.4mm on day one pretty much guarantees they'll be >26mm in no time.
As a hyper-recent example. The Challenge Strada Pro HTLR I just installed on Tuesday night were 25.4-25.5mm on 19mm internal rims. After three days of riding they are already 26.0-26.1mm.
Just seen the UK distributor had 6x 28mm black in stock so bought them. Next batch said to be March.
I have 22x 28c on order, so hopefully these will get out well before then!
IG: RhinosWorkshop
IG: RhinosWorkshop
The test methodology is a little confused, yes. I used to speak French well, but I'm rusty; I'm a native Anglophone, but I was unclear on the methodology regardless of whether I read the post in French or Google English.TobinHatesYou wrote: ↑Sun Oct 10, 2021 9:46 pm
What's not great about the rollers+SRM? Is it the ambiguity I mentioned above, or do you have a broader objection to the methodology? There's no wrong answer here...I'm just trying to follow your argument.
Objectively, it's not clear to me that a 10% improvement is reliably detectable with that setup, but I don't have enough info to be sure.
youngs_modulus wrote: ↑Tue Oct 12, 2021 2:27 amThe test methodology is a little confused, yes. I used to speak French well, but I'm rusty; I'm a native Anglophone, but I was unclear on the methodology regardless of whether I read the post in French or Google English.TobinHatesYou wrote: ↑Sun Oct 10, 2021 9:46 pm
Your last sentence sums it up. There's a lot of sources of noise in his setup whether it's his legs, lateral movement, no secondary power measurement. Does he sufficiently clean the rollers between tests? Did he maintain the same room temperature or at least roller temperature between tests? I know he said he allowed it to warm up, perhaps that's sufficient. I honestly don't know.
I like Aerocoach's approach of both using a drum and then following up with real-world tests.
conti are saying its perfectly fine to run with tubes85L wrote: ↑Mon Oct 11, 2021 6:49 amNot exactly, that's the opposite. He's saying first that 5000TL is 0.5W faster that 5000STR. But this difference is revealed with panaracer R'air tubes and that's not the way this tyre has to be used since it's a tubeless (ready) tyre.petromyzon wrote: ↑Sun Oct 10, 2021 5:13 pmhttp://www.cyclesetforme.fr/essai-roule ... 5000-s-tr/
I think I saw where Conti was saying it was faster than the tube GP5000 though you don't know if that was tested with Latex tubes and they are 30g heavier per tire.
I do have one person in my club running a tubeless tire with a tube as it was nearly new when it got a puncture that wouldn't seal with sealent and he didn't want to buy a whole new tire.
2015 Wilier Zero.7 Rim - 6.37kg
2020 Trek Emonda SLR-7 Disc - 6.86kg
2023 Specialized SL7 - 7.18kg
