The Roval Rapide I think are 18 spokes at the front.alcatraz wrote: ↑Sat Jul 31, 2021 8:03 amI'm surprised that 21h front wheels are a common thing now.
They aren't dished significantly to either side and thus they shouldn't really be triplet. A 21h front wheel has only 7 spokes on one side, just like a 14h wheel.
Would you descend confidently on a 14h wheel if you're a heavy rider?
New Vision Metron 45SL first look!!
Did you check the weight? Was it really 1380gr? Is that with tubeless tape and/or valves?
Nice to see major brands catching up with small Chinese brands in the weight game. LightBicycle WR45 standard weight with Carbon-Ti hubs and 24/24 CX-Ray is 1409g.
You're right! I forgot about that wheel. It only has 6 spokes on one side.pmprego wrote: ↑Mon Aug 02, 2021 2:45 pmThe Roval Rapide I think are 18 spokes at the front.alcatraz wrote: ↑Sat Jul 31, 2021 8:03 amI'm surprised that 21h front wheels are a common thing now.
And people complain about 24 spoked wheels being too risky because if you break a spoke you can't get home.
I feel like this the wheel I have been waiting for. Please tell us more about your impressions after a few rides, especially on the freehub and stiffnes.
I guess you (and me) will have to wait for online reviews to start appearing.nulldreiundreissig wrote: ↑Tue Aug 03, 2021 1:36 pmI feel like this the wheel I have been waiting for. Please tell us more about your impressions after a few rides, especially on the freehub and stiffnes.
first & second test use Aethos 8.2kgs. total bike weigth and the S4 test use F12 total weight is 9.5 kgs.
First test :
second test next day
today test with Ventoux S4
the first ride and second ride was very impressive, the stiffness of the hub are very amazing, using a 72T, it is very good sound and very good for climbing. very very stiffness and faster reaction.
the second ride, the aerodinamic wider rim makes the descent incredible.
the ventoux s4 very impressive, good stiffnes because the carbon spokes, the hub low noisy, if change to CS will be great!!!
comparing these two wheels, S4 are more cheaper and enough to climb, The vision metron have the best hub of the world.
First test :
Two things:alcatraz wrote: ↑Mon Aug 02, 2021 4:34 pmYou're right! I forgot about that wheel. It only has 6 spokes on one side.pmprego wrote: ↑Mon Aug 02, 2021 2:45 pmThe Roval Rapide I think are 18 spokes at the front.alcatraz wrote: ↑Sat Jul 31, 2021 8:03 amI'm surprised that 21h front wheels are a common thing now.
An unrelated comment: there is a photo of an unreleased 1200'ish gr hunt wheel with 16 carbon spokes front :O
Any news regarding the vision 45SL?? On paper, these are a really interesting candidate for what I'm looking for but nothing besides marketing claims.
I know this is months old, but why would high engagement be beneficial to road climbing where there is more-or-less zero coasting? Even if we’re talking about rolling terrain, you should be pedaling before the road starts tilting up again.
I also have one metron, I can sure my point
At present, it is aimed at the climbing test. The total length of the climbing section is about 13 kilometers. There are two flat roads with a distance of about two kilometers. The entire section can be regarded as 10 kilometers for climbing. From 6% gradient to 18% gradient, the inertia of the entire wheel is very good, the conversion speed is also great, and the rigidity is sufficient for climbing, but it is not as good as the carbon fiber web. In the upper-middle level, it's a pity that the price is still not cheap. This time the hub should have the function of strengthening waterproof. For rainy weather, under low temperature and humid conditions, it can play the rotating speed very smoothly. This point FAR SPORTS VENTOUX S4 will become a serious fatal injury, because the hub is open. In this way, the inability to fully protect against the threat of moisture leads to early infiltration of moisture and triggers the operation of the hub. This is what we call a rust reaction. This really needs to be strengthened to improve the design of the hub to compensate for the entire rust. problem.
Don't reply to this user. Nor the one below your post. They are the same. He/she does have access to the material (or not... a copy, don't know) but his/her analyzis are no good.TobinHatesYou wrote: ↑Mon Oct 25, 2021 11:53 am
The classic Shimano c24 shallow carbon laminate clinchers were 16fr 20r spoke count. Plenty of big riders on those back in the day.
I think there is plenty of market for wheels that are aero with 28mm tyres. Especially now that 28mm actually means 28mm and not 31mm. I'm pretty certain that for the vast majority of UK roads a 28mm is a better choice; even if I could be just as fast on a 25mm I wouldn't want to risk the rim damage.
Yeah but these hunt are disc brake wheels.petromyzon wrote: ↑Mon Oct 25, 2021 7:45 pmThe classic Shimano c24 shallow carbon laminate clinchers were 16fr 20r spoke count. Plenty of big riders on those back in the day.
There's a balance to be struck. These new Visions are definitely optimised for a tire wider than an actual 25mm, so if you want to use an actual 25mm then it won't be ideal most of the time. What size of tire do you optimise for though? An actual 28mm on the front is now common amongst the pros. and perhaps for good reason. At Roubaix you now see some examples of a 32mm tire on a 60mm rim - niche for the pros, but it's still road, not gravel. Next year they'll be many 30mm tires at the Classics.Nickldn wrote: ↑Sun Aug 01, 2021 9:55 amThat's the thing you see, I don't think that wider wheels are more aero, I think they are less aero.
We have been told wider tyres have a lower RR, so then you need wider wheels for the 105% aero rule. But when you get to 33mm wide wheels that means you can run 31mm tyres and still not break the 105% rule. Who is going to run 31mm tyres with 60mm deep wheels? That's a niche market. Gravel aero?
So why manufacturers are making these wide and deep wheels is what I'm trying to understand. What's the benefit for someone who uses 25mm tyres?
The 105% rule was really always a rule-of-thumb and it definitely doesn't give one perfect answer. Key to the new generation of rims is acceptance that shape (of the tire and rim as a unit) is just as important as actual size, generally with a yaw of more than about 5 degrees. Once you start looking at 12+degrees yaw and especially once the airflow is "stalled" at higher yaw, then handling becomes a real factor and that's where the fatter rim (at the front) really shines. Aero has many different "definitions".
