Tubeless burping… or something else?
Very bizzare:
Winspace Hyper 50mm (rim brake). Hutchinson Glactic Fusion 5 25mm (tubeless) fitted.
As a test, the tyre was inflated two days ago (no sealant) and kept its pressure (circa 80psi) fine.
I gave the tyre a squeeze... it felt perfect... drooled over the wheel... put it down again... made a cuppa tea... picked up the wheel again (to put it back where it was) noticed all the air had escaped!
Seems the act of lifting the wheel and placing it somewhere else (maybe a bit of touching parts) led to a rather quick purge of air (which I couldn't hear over the kettle).
Any ideas? I can only think of dodgy valves that might let go so suddenly?
Ps The tyre is very well seated on the rim (ie very hard to get off the seat when deflated). No way the tyre became unseated.
Here's a secret: There is no point in fooling around with "no sealant."
You got lucky upon initial install...you disturbed it and gap opened somewhere. If you had sealant in the tire, this would have sealed within a couple rotations of the wheel/tire or a couple of shakes.
I fully intend to run the system with sealant - it's good to see if there are any leaks in the system beforehand (rather than them being masked by sealant)...
...and this is what's concerning me... the rapid drop in pressure, which may mean that one of the components isn't up to scratch IMO.
Slow leaks sometimes aren’t that slow. Add sealant and ride.
You clearly don't understand tubeless. Stick with innertubes.
IG: RhinosWorkshop
IG: RhinosWorkshop
Of course there are leaks in the system! There's about four metres of tyre/rim interface to seal not to mention tubeless tape and valves. For me it's impressive your wheel kept any air at all. Sealant is what makes tubeless work. Just bung some in and ride and stop stressing about theoretical concerns.Oms wrote: ↑Tue May 25, 2021 8:12 amI fully intend to run the system with sealant - it's good to see if there are any leaks in the system beforehand (rather than them being masked by sealant)...
cycling / nature / music
Okidokers - will do.Miller wrote: ↑Tue May 25, 2021 11:23 amOf course there are leaks in the system! There's about four metres of tyre/rim interface to seal not to mention tubeless tape and valves. For me it's impressive your wheel kept any air at all. Sealant is what makes tubeless work. Just bung some in and ride and stop stressing about theoretical concerns.Oms wrote: ↑Tue May 25, 2021 8:12 amI fully intend to run the system with sealant - it's good to see if there are any leaks in the system beforehand (rather than them being masked by sealant)...
Still waiting on a frame. New wheelset excitement is currently torture.
Thanks. Good to know.
I've run TLR setups on DtSwiss and Mavic rims with no problems so far (apart from the nightmare of getting GP5000s mounted).
How are you finding the suppplied valves? I think they're not quite long enough without the extensions... and way too long with them.
