New Bora Wheels?
CustomMetal
by CustomMetal
Are campy about to update the WTO line up?..
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Uselessman001
by Uselessman001
Maybe it's BORA WTO ULTRA DB 45/60.
It's already listed on the UCI approved wheel list.
https://www.uci.org/docs/default-source ... ls-eng.pdf
- Factor OSTRO VAM
- Cinelli STRATOFASTER
Antoine22
by Antoine22
Yes it's WTO ultra. My LBS told me this 2 weeks ago already
CustomMetal
by CustomMetal
Are the ultras disc brake only?
Bertha- TT 9.8kg
FlatlandClimber
by FlatlandClimber
Looks hookless... please not 😫
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
CustomMetal
by CustomMetal
FlatlandClimber wrote:
Tue Apr 20, 2021 8:28 pm
Where did you see this?
Bertha- TT 9.8kg
itsacarr
by itsacarr
CULT!
Just ride ..
kevinw
by kevinw
Maybe slightly wider? I struggle for aero tyres on my WTO as most 25mm tyres actually measure more than 26.5mm when fitted.
FlatlandClimber
by FlatlandClimber
CustomMetal wrote:
Tue Apr 20, 2021 8:34 pm
It just looks from the image...
TobinHatesYou
by TobinHatesYou
If we're going by the image, it's definitely NOT hookless.
ichobi
by ichobi
Should be announced today. In light of thr new zipp, i would say from the spec sheet the new bora ultra is VERY conservative. They are pretty tho.
TobinHatesYou
by TobinHatesYou
ichobi wrote:
Wed Apr 21, 2021 6:06 am
They're probably not US$4000 either.
Aeo
by Aeo
https://solobici.es/campagnolo-bora-ultra-wto
Google Translate wrote:Leap of quality with the new Campagnolo Bora Ultra WTO wheels
Campagnolo has made a qualitative leap in its range of wheels with the new Bora Ultra WTO , with a plus of lightness, rigidity and aerodynamics.
These wheels are created to be specifically compatible with disc brakes in 33, 45 and 60mm rim versions, and have almost three years of research and development behind them.
That's why it features the latest in technology, like the Aero Mo-Mag internal nipples inside the rim for improved airflow. But not only is it an aerodynamic advantage, it has also helped to increase the stiffness of these wheels as no holes are required in the carbon fiber for the nipples and valves as they go directly to the rim mold.
Bora Ultra WTO
Another aspect to highlight is the ultralight HULC carbon construction for a weight of just 1,425 grams in the 45 mm version, or even the C-LUX finish that does not require painting and has also saved weight. CULT (Ceramic Ultimate Level Technology) bearings, meanwhile, are more durable, wear less and are more efficient than those that are usually made of steel.
The asymmetric G3 system is also present to improve braking power transfer, while the patented N3W freewheel body accommodates 11, 12 and 13-speed Campagnolo sprocket pack.
These wheels have already been extensively tested thanks to the collaboration of WorldTour teams such as UAE Team Emirates, Lotto-Soudal and Ag2R-Citroen Team.
Campagnolo Bora Ultra WTO wheels are now available at official distributors for a price of 3,150 euros .
Giant TCR Adv Pro Disc '17 · BH Lynx Race Evo '19 · Seraph GR029 '21 · Canyon Inflite AL '14
TobinHatesYou
by TobinHatesYou
Aeo wrote:
Wed Apr 21, 2021 9:06 am
[/quote]
Yikes, actually pretty close to NSW pricing depending on regional pricing quirks.
bespoke
by bespoke
The end of rim brakes is getting closer and closer when Campy give up....
Warning - Inherently biased:
www.bespokecycling.com
