Farsports Kaze wheelset delaminated or brake residue?
Hello everyone, just want to get some thoughts of those sighs on brake tracks.
I found those signs after purchased 2 months and about 1000km, i was told by Farsports thats caused by brake pads and would be faded out by daily ride.
But after half a year, more than 3000 km now, the sign still here and i am thinking if the wheelset was delaminated. Many short climb here but never had big decents though.
I don´t think you could ride it for 2000km if it was delaminated?!?
Delamination should give you other signs - brake puls, visual delamination/deformation of the area, fiber destruction etc. If it was heat delamination i would expect the grooves to be gone/destroyed in that area.
Any other signs than the visual discoloration?
Have these rims as both grooved and non-grooved. what pads do you use?
EDIT: If clincher and heat delamination - you typically see some deformation of the rim-shape caused by softening of the resin at very very high temperatures (these rims are pretty good at heat management and stability)
EDIT 2: Try cleaning them with Acetone and a lot of hand-work to remove brake pad residue and take a look again.
How then did you solve this problem?
This is probably only visually or were these the remnants of the brake pads?
Are the wheelset still in use?
I also have this 'brownish' effect, mostly on my rear kaze wheel. I noticed a severe drop off in braking performance. After some cleaning(not with acetone tho, just water), I got some performance back, but it's not perfect. I'll try with acetone as well this weekend and report back here. I use Reynolds CryoBlue pads, which have been excellent for the most part in combination with these rims. Front wheel brakes like a dream. Front wheel also has this colour, although a bit less severe, but I didn't notice any performance difference. Structurally everything is still perfect.
I suspect the colour will never fully go away, which is a shame since the wheels & bike are matte black
That's not delaminated but looks to me like the wheels were build with glasfiber, aramide or kevlar and not carbon and only the outside of the rims are made with carbon.vanbobo wrote: ↑Sat Apr 17, 2021 5:18 amHello everyone, just want to get some thoughts of those sighs on brake tracks.
Once comes a time that you'll have a tailwind
Pinarello F10 - Ultegra 8050 Di2 - Carbonspeed C38 Tubeless
Answer from Farsport -->
Problem: Yellow/brown tracks on the brake area
(picture_1)
When braking to high temperature ,the brake pads was melt and rubber residues are left on brake track . Our wheels with high temperature durable and good braking performance. so high request for the brake pads is necessary, The brake pads also need high temperature durable to match it. If not, when we have little yellow brown tracks, normally it won’t effect the braking performance, But if it is too much , it will effect braking even cause squealing when you brake. we would like to suggest use 3M scotch-brite to wipe it.
(picture_2)
Or you can choose brake pads of Swissstop black prince EVO, better than yellow one after our testing
Here is the photo of braking area after 4KM braking continuously .
(picture_3)
(picture_1)
(picture_2)
(picture_3)
