DT Swiss 240 EXP - Engagement Problems
haze513
by haze513
Anyone else experienced this?
Few miles into today's road ride and I get total loss of engagement in the freehub resulting in a call home for a pick up.
Get home, remove the cassette to take a look and everything is working again.
Little over 1000km on this hub...
jekyll man
by jekyll man
Normally its too much grease/ wrong grease problem after servicing them that causes the 2 gears to "hydraulic" themselves apart.
Official cafe stop tester
haze513
by haze513
Not too familiar with how the ratchet system works yet, early days using it.
So does the ratchet engage and disengage via the spring...if some additional grease found its way in there (off the splines for example) could that cause the ring to stick preventing re-engagement?
BadBoyR
by BadBoyR
jekyll man wrote:Normally its too much grease/ wrong grease problem after servicing them that causes the 2 gears to "hydraulic" themselves apart.
This! I had the same issue with a new xdr hub mounted on new wheels. When I tried to remove the protective covers off the axle the hub came off, so I thought I’d pack it with grease. It wouldn’t engage so I took it apart and reassembled a couple of times.
haze513
by haze513
It's a new hub and not had any grease added, I did apply a tiny bit of chain lube on the splines but just checked and there doesn't appear to be an excessive amount of grease in the assembly.
Also if I get caught out again, is it possible to remove the freehub with cassette attached?
Assume this would gain me access to free the ring and hopefully get moving again...
jas0nt
by jas0nt
Known issue with early production batches.
https://www.mtbr.com/threads/dtswiss-24 ... m.1158241/
If it keeps happening, put a warranty claim in.
pdlpsher1
by pdlpsher1
I read the last two pages of the provided link and now I'm getting worried. I have two sets of wheels with the EXP hubs. My wheels were built in Feb. and who knows if mine are affected by the defect. It looks like the entire hub will need to be replaced so a wheel with the defective hub has to be shipped to a service provider to be rebuilt. What a pain. Keeping my fingers crossed that mine are not affected.
MagicShite
by MagicShite
known issue.
DT Swiss should just do a recall on this.
It's actually *f##k* dangerous. Imagine crossing the road halfway and the hubs wouldn't engage.
EDIT: Sold 10+ EXP units here from where I'm from and right now one of the DT180s have that issue. (+_+)" I'm worried about the other units.
pdlpsher1
by pdlpsher1
Agreed on the danger and the need for a recall. When a recall is issued they provide the affected serial numbers. Right now I have no idea if mine are affected by it. Someone on the MTBR forum said his wheels were received in Dec. from LB and his was defective. Mine was built by LB sometime in Feb. and received in Mar. Keeping my fingers crossed.
jas0nt
by jas0nt
TBH it put me off DT Swiss for my new LB build. Why take chances on it when there are so many other proven hubs out there as an option.
haze513
by haze513
pdlpsher1 wrote:
Sat Apr 03, 2021 6:34 am
Mine were from LB, almost exactly the same time for the build so it's a fair bet my hubs are from the same batch.
I'll drop DT a line and see what comes back, hopefully it's a swap job on the internals rather than a full hub change.
Jas0nt, thanks for the link.
BadBoyR
by BadBoyR
My hub is on a set of new roval rapides, could it be the xdr driver that was installed the issue?
haze513
by haze513
Not XDR here, Shimano 11sp
rides4beer
by rides4beer
haze513 wrote:
Fri Apr 02, 2021 11:57 pm
Yes, the freehub and cassette will just pull off together with no tools needed, should be able to do it on the roadside and get rolling again. :thumbup:
I have a set of LB wheels on the way with DT240 EXP hubs, I'll def keep an eye on them.
haze513
by haze513
Sweet, cheers...just tried and it was easy enough, hopefully no more waiting around freezing my nuts off 30 odd miles from home!
Hope DT sort something though, confidence is a bit low in these at the minute
