Best handling 40-50mm wide disc clinchers?
I'm currently running a Venge with a set of Roval CL50 with 25mm front/28mm rear GP5000S TL tires.
I initially planned on using the stock wheels because their width (20.7/29.4mm) allows to adhere to the 105% rule with these tires, but I find myself hating them in crosswinds, they feel really nervous so I want to switch them out for something else.
So the question is what wide disc clincher wheels with a 40-50-mm profile handles wind best? I've read recommendations of the Reynolds Aero DB series, even some people swapping exactly the CL50 wheelset out for them to get better handling, but they are not available in my country & taxes make them too expensive to import.
How about stuff like the Knot wheels that come with the SystemSix f.ex., or the 3T set? Any recommendations?
Rapide CLX, that front wheel is magic. Just road a friends SL7 and was shocked at how well it behaves in cross winds.
State Bicycle Co. Undefeated: viewtopic.php?f=10&t=171358
Thanks, did you consider the even wider WR45 Falcon?
Thing that gets my confused is that there are so many mixed reports with the CL/CLX 50, they feature the same rims on both models, so I'm really confused as to why a wheelset that's being used regularily on the WT can feel so nervous to some yet be praised as one of the best handlers by others.
I'm using the previous generation model, not the one they released last year that didn't have tubeless support. I see they claim Rapide CLX 2020-gen is "25% more stable" than the previous gen wheels. Although it's hard to take Specialized's marketing at face value, it looks like they might actually have fixed the rim design handling issues.
It is sacrelige to hear for some but I always thought toroidal rims are the best in crosswinds. That puts the widest point in the middle of the rim so the wind can go around both ways without much difference. This assumes the tire isn't wider than the rim at the interface.
Just look at enve wheelsets. The front is much more toroidally shaped than the rear, and shallower.
CL50 looks like a V-shaped rim with the widest point at the tire interface.
This.
And these...
Fast. Stable. Solid.
Through the Valleys and over the Mountains...
2013 Ridley Helium - 6.9Kg
2017 Blue ProSecco - 9.0Kg
2018 Ridley Noah SL - 7.85Kg
I never rode WR45, so it's hard to say..andreas wrote: ↑Thu Mar 11, 2021 12:17 amThanks, did you consider the even wider WR45 Falcon?
Have used the Hollowgram Knot 45s in all manner of conditions and they handle as well as any deep rim, and better than my Zipp 404s, in serious wind. I'm only 60kgs and rode them through a British winter. Just be careful you get the 'SL' model with the better hubs if you do go for them. With Corsas they were sublime.
Cannondale SSEvo3 'Atticus' - 7.2kg
viewtopic.php?f=10&t=161634
Cannondale Systemsix ’Dante’ - 7.7kg
viewtopic.php?f=10&t=167144
I ordered the WR50 for the front on my set since they got great reviews in cross winds. Even the WR65 seemed to do ok based on reviews but I think the couple people that have said that were closer to my weight or more at 85kg+.
I run 28 mm Corsa Controls front/rear on WR50s, they measure ~31-32 mm and this is the minimum width I would feel comfortable with, and even then I need a tire with wide tread for peace of mind. Excellent crosswind handling, very controllable with gusts of 30+ mph. Caveat, my total weight (me + bike) is about 90 kilos; much lighter riders will probably not do so well in crosswinds.
While the 2020 Rapide CLX sounds like they're really good handlers (also confirmed by the Hunt white paper as far as I can tell), pricing and tubeless compatibility makes the LB AR/WR series more attractive... Anyone tried both in windy conditions?
