Oh I see, so you take the tyre and tubeless valve off after every rain? Seems a bit hard.jesper2913 wrote: ↑Sun Jan 10, 2021 9:08 pmMaybe it's the language barrier. English isn't my first language. Sorry if it's unclear.musiclover wrote: ↑Sun Jan 10, 2021 3:22 pm
Didn't understand that. If a wheel is in a bicycle, valve hole at the top (facing downwards) would mean water will be at the bottom where there is no hole?
I have let the water out creating a bit of a momentum and freeing the valve hole.
I hang the wheel to dry with the valve hole positioned for the water to run out of the rim at the bottom.
Water build-up inside carbon rims with no drains
- musiclover
I have retired from this forum, not wasting any more time here.
Not exactly. I don't ride tubeless. I ride clincher wich makes it easy to remove tube and tire.musiclover wrote: ↑Mon Jan 11, 2021 12:51 amOh I see, so you take the tyre and tubeless valve off after every rain? Seems a bit hard.
In your case, where there are no drains, I wouldn't ride them tubeless. IMO they are not 100 % tubeless ready, if there aren't any drains.
- musiclover
No thanks, once I tried tubeless I will never go back to inner tube.jesper2913 wrote: ↑Tue Jan 12, 2021 1:26 pmNot exactly. I don't ride tubeless. I ride clincher wich makes it easy to remove tube and tire.musiclover wrote: ↑Mon Jan 11, 2021 12:51 amOh I see, so you take the tyre and tubeless valve off after every rain? Seems a bit hard.
Sure. But then you will have the problem of water builing up inside the rim. You can't have it both ways.musiclover wrote: ↑Wed Jan 13, 2021 7:40 amNo thanks, once I tried tubeless I will never go back to inner tube.
- musiclover
The problem is not specific to tubeless, it is just a bit harder to fix with tubeless.jesper2913 wrote: ↑Wed Jan 13, 2021 1:12 pmSure. But then you will have the problem of water builing up inside the rim. You can't have it both ways.musiclover wrote: ↑Wed Jan 13, 2021 7:40 amNo thanks, once I tried tubeless I will never go back to inner tube.
I am fully aware. That is how I know, how to fix it as mentioned above. But you wanted cheap chinese carbon wheels (nothing wrong with that btw), that weren't fully prepared for tubeless, and now you have a problem.musiclover wrote: ↑Wed Jan 13, 2021 7:05 pmThe problem is not specific to tubeless, it is just a bit harder to fix with tubeless.
- musiclover
Correction: expensive Chinese wheelsjesper2913 wrote: ↑Wed Jan 13, 2021 7:56 pmI am fully aware. That is how I know, how to fix it as mentioned above. But you wanted cheap chinese carbon wheels (nothing wrong with that btw), that weren't fully prepared for tubeless, and now you have a problem.musiclover wrote: ↑Wed Jan 13, 2021 7:05 pmThe problem is not specific to tubeless, it is just a bit harder to fix with tubeless.
I do not think Enve 4.5 AR or Zipps necesarily have drain holes... I.e., there is no direct correlation between the wheel brand level and drain holes presence.
Moreover: it does not cost anything extra to have your drain holes drilled at any chinese manufacturer, just need to remeber to ask... do not think you can do same with big brands.
I really hope those chinese ingeneers do the math to make sure, that the structure holds despite holes being drilled into it by the vendors.musiclover wrote: ↑Thu Jan 14, 2021 6:12 amMoreover: it does not cost anything extra to have your drain holes drilled at any chinese manufacturer, just need to remeber to ask... do not think you can do same with big brands.
- musiclover
One does not need to be an engineer in order to drill a drain hole. One just need to drill it at the right spot with the right drill. And a good thing about doing it like that at the factory is that they then assume all responsibility.jesper2913 wrote: ↑Thu Jan 14, 2021 8:46 amI really hope those chinese ingeneers do the math to make sure, that the structure holds despite holes being drilled into it by the vendors.musiclover wrote: ↑Thu Jan 14, 2021 6:12 amMoreover: it does not cost anything extra to have your drain holes drilled at any chinese manufacturer, just need to remeber to ask... do not think you can do same with big brands.
Apparantly Enve has a bit of problems with their rims being too tight - air seeping from the (tubeless) tyre into the cavity of the rim blowing it up. Something as simple as a drain hole would have solved it...musiclover wrote: ↑Thu Jan 14, 2021 6:12 amCorrection: expensive Chinese wheelsjesper2913 wrote: ↑Wed Jan 13, 2021 7:56 pmI am fully aware. That is how I know, how to fix it as mentioned above. But you wanted cheap chinese carbon wheels (nothing wrong with that btw), that weren't fully prepared for tubeless, and now you have a problem.musiclover wrote: ↑Wed Jan 13, 2021 7:05 pmThe problem is not specific to tubeless, it is just a bit harder to fix with tubeless.
- musiclover
Don't they have those new fancy pressure releasing tubeless valves to assist with this problem?
PS I actually think that drain holes are a good idea. It is just silly that it is not a default option and you need to ask for it. Easy to forget ecspecially if it is your first set.
True. I'm not an engineer, and even I know how to operate a drill.musiclover wrote: ↑Thu Jan 14, 2021 8:59 amOne does not need to be an engineer in order to drill a drain hole. One just need to drill it at the right spot with the right drill. And a good thing about doing it like that at the factory is that they then assume all responsibility.
That is not the point though. The point is, you need an engineer to do the math to ensure, that the product has the structural capabilities to withstand normal use after such a drilling. I really doubt, they run it by an engineer before drilling it.
And who cares who assumes responsibility if your front wheel colapses riding through a pothole and you fall face first towards the tarmac with 60 km/h downhill.
And the best of luck making a chinese vendor responsible for your injuries.
You dont think a chinese manufacturers is capable of making a drain hole? How do you think they make holes for spokes/valves?jesper2913 wrote: ↑Thu Jan 14, 2021 11:18 amThe point is, you need an engineer to do the math to ensure, that the product has the structural capabilities to withstand normal use after such a drilling. I really doubt, they run it by an engineer before drilling it.
FWIW, I asked LightBicycle about drilling my rims, and their answer was simple, dont do it. They do make drain holes on request, but then they reinforce the rim first.
- musiclover
Wow, a wheel exploding at 60 km/h on downhill. That is such a vivid picture from someone who doesn't mind cheap Chinese carbon.That is a very probable scenario.jesper2913 wrote: ↑Thu Jan 14, 2021 11:18 amTrue. I'm not an engineer, and even I know how to operate a drill.musiclover wrote: ↑Thu Jan 14, 2021 8:59 amOne does not need to be an engineer in order to drill a drain hole. One just need to drill it at the right spot with the right drill. And a good thing about doing it like that at the factory is that they then assume all responsibility.
I will not drill it myself due to the other reasons though, which I listed above.
