Best/Fastest 45-50mm Tubeless wheelset
Yoln
by Yoln
On the market for a new pair of wheels
Looking for tubeless in the 45-50mm deep range
Reading Hambini test, it looks like these 3 are the most aero:
- Borg 50c
- Yoeleo C50
- Bora One 50
https://www.hambini.com/testing-to-find ... le-wheels/
My eyes are very attracted by the Bora WTO 45mm, is it safe to assume they are as good if not better than the ultra (better rim profile, wider rim)?
Any other competitors in mind (assuming $2000 max budget)?
Wilier “Cento Ramato“ : viewtopic.php?f=10&t=160943
Lynskey “the Do-it-all Helix” 🧬: viewtopic.php?f=10&t=161550
FlatlandClimber
by FlatlandClimber
The general rule goes: a deeper wheel will likely be faster than a shallower wheel. Also, get a width, that fits the tire width you want to ride. I don't think there are any wheels that are fastest with a 28c. I have the ENVE SES 4.5 AR (which are massively wide) and they are faster with a 25c than with a 28c. Many other wheels will be faster with a 23c than with a 25c (I am talking aerodynamics, rolling resistance is a different thing again and totally depends on the speed and surface).
I guess the fastest wheel (in any situation) at "around" $2k is the Roval Rapide CLX. They work perfectly with 25c, are fast, and also have the least steering moment at cross winds of any wheel that I own (Rapide CLX, CLX64, Hadron2 800, ENVE SES 4.5 and 5.6, ZIPP 858).
If that is too much and you are not on a time crunch, maybe weight for the lighter version of them set to release a few months down the line.
A fast rolling tire will likely make a bigger difference, than the difference between two equally deep wheels will ever be, so go check on that front also.
Cervélo S5 Disc (2019) - 7.8kg
Open Cycles WI.DE (2019) - 8.5kg
Specialized Shiv TT Disc (2020) - 7.9kg
Specialized SW Aethos (2021) 6.4kg
Trek Émonda SLR9 (soon)
*all weights include pedals, computer mounts, and bottle cages.
Yoln
by Yoln
Thanks
Consensus seems to be in favor of the WTO 45mm versus the Cl/CLx here: viewtopic.php?t=160782 at least in windy conditions
That's a good question about the tires, I'll be riding them with 25mm fast tires when racing. Potentially GP5k tubeless or Vitoria Corsa/corsaspeed tubeless, so not much to gain over there...
Cycomanic
by Cycomanic
Yoln wrote:Thanks
I heard the GP5k in tubeless are quite difficult to get onto the WTOs, but I've never tried. I'm very happy with my wto45/pro1 combo (in 25mm), very easy to put on didn't even need levers. And the pro1 roll very nicely.
Another wheelset to consider are the winspace hyperX, they tested very well with hambini and peak torque also rated the highly on stiffness.
Sent from my LYA-L29 using Tapatalk
Kaludrob
by Kaludrob
FlatlandClimber wrote:
Fri Oct 09, 2020 5:41 pm
The fastest wheels in that range were the DTSwiss ARC1100 in the latest Tour mag.
2018 Specialized Tarmac Expert
Greatestalltime
by Greatestalltime
dolophonic
by dolophonic
I/d go CAmpy Boras//
FlatlandClimber
by FlatlandClimber
Kaludrob wrote:
Sat Oct 10, 2020 12:22 pm
Although I am a fan of the new DTs (I have the identical Swiss Side Hadron2 Ultimate as 80mm for my TT bike), I doubt you could call 0.3W faster in a wind tunnel "a faster wheel". No power measurement tool I know it is reliably more accurate than +/- 0.5%, so really unlikely, this can be verified.
Nevertheless, it really depends on what you want. The Rapide are probably the fastest (aero + weight) option if you don't need/ want TL. Also, it is by far the most stable in crosswinds I have ever used in my life.
If you want TL, the DT/ Swiss Side are definitely a great Option, too.
Milese
by Milese
I've not translated the words, but what this tells me from what I can see is....
40mm deep @ 30mm wide = 223w
45mm deep @ 27/28mm wide = 219.5w ish (Bora & Enve)
50mm deep @ 27 / 35mm = 218w ish (DT Swiss & Roval) - not quite an equal comparision, but guess the narrowness of the DT gives similar gain as the extra 1mm depth front and 10mm on the rear?
So, shock horror, deeper wheels are more aero....(small sample size and not sure what they did with tyres etc)
Is there any reason to think that Farsports etc wheels of the same sizes would test any differently?
Kaludrob
by Kaludrob
to be honest i dont think so. I would get the lightbicycle Falcon pro ar45 with Carbon ti hubs and sapim spokes. A below 1300gr. Wheelset for 1300 USD plus shipping
Yoln
by Yoln
Awesome, thanks for the data!
Rovals are also a strong contender in that test if you consider Speed and Stiffness
Any more details on how the compute the seitenstefigkeit / lateral stiffness number? Actually all the numbers if you have :)
Yoln
by Yoln
Kaludrob wrote:
Sat Oct 10, 2020 3:52 pm
That's what the reasonable inner me is telling me as well. My climbing LB 35 falcon pro flyweight are doing an amazing job at 1245g (dts240 hub) and I wouldn't mind going the same way for deeper ones. But there's also the other inner me that just wants a pair of butter smooth gorgeous campy WTO...
Yoln
by Yoln
Cycomanic wrote:
Sat Oct 10, 2020 8:55 am
Nice, definitely very aero. Pretty heavy for a wheel with carbon spokes no? 1425g for a disc version, that's about 100g heavier than what I can get from LB with Sapim spokes...
ViperFFM
by ViperFFM
Yes it is weightweenies but it should be commin knowledge now that a weight diffrence of couple of hundred grams in neglectable compared to aero gains.
ID go Fulcrum Wind DB55
stevesbike
by stevesbike
Sat Oct 10, 2020 1:05 pm
They aren't directly measuring power - it's a conversion based on drag that consumers find more informative. But you're right on the bigger point: the small differences in these wheels makes them essentially equivalent, and the Zipps are shallower so of course you'd expect them to be slightly less aero.
