Goodyear UHP tubeless tires
Forum rules
Sadly my second Goodyear eagle F1 TLR died yesterday, I heard a loud bang and then there was a rapture in the rubber but it still held the air. So in 2500km I have been forced to change 2 Goodyear tires but my GP5000TL has zero issues despite being used more and on worse roads.
Goodyear seemed promising but the puncture resistance/quality is to bad.
I ordered the Eagle F1 a few months back, finally needed to replace my old tyres so mounted them up.
Front went on nice and easy, seated with little effort, added sealant and moved to the rear. Quite happy at how smooth the front went, seating the rear....went OK and seated fine......but then...sound of air hissing out, damned pin hole appeared from nowhere! Sadly will end up binning these without even trying them, although from more recent comments, looks like I'm probably not missing out on anything.
Sent from my SM-F711B using Tapatalk
can someone tell me this combo will work
HED rim 21 I.D. 25 External
Goodyear 25mm 4 season vector. Would the 25mm be too wide covering the rim? (was looking for 23mm tires but most tubeless starts with 25mm minimum)
PoorCyclist wrote: ↑Sun Dec 05, 2021 8:19 pmcan someone tell me this combo will work
25mm external is narrow, and no you shouldn’t buy 23mm tubeless tires regardless of your rim situation.
