Forum rules
TobinHatesYou
by TobinHatesYou on Tue Oct 27, 2020 4:32 pm
Singular wrote: ↑Tue Oct 27, 2020 11:24 am
There you have it - a classic sidewall cut which is nothing unusual with very thin/supple cotton/silk casing tires when riding somewhere they're not supposed to go (like sharp shardy gravel). I do also assume that the stress on a single point is also more prounced when riding tubeless (as there is no tube to spread the load over the sidewall), which means that failure is accelerated when a point of damage occurs.
That doesn’t explain the constant radius circumferential abrasion/wear along the sidewalls. That kind of damage is from sidewall collapse/folding.
Maddie
by Maddie on Wed Oct 28, 2020 3:02 pm
That tire looks fairly beaten up. I ride both Corsa Evo TLR and Race TLR in rain, sometimes gravel. Always 6.0 bar front and 6.5 rear (67 kg) and never had a flat. I'm actually surprised how durable they are considering the comfort and subtle feel they deliver. Was riding Turbo Cottons with latex before but wanted to go tubeless. I think that's the closest to the TC/latex you can get. Definitely a fan of Veloflex TLR, just need to be careful to replenish sealant regularly.
Maddie
ultimobici
- in the industry
by ultimobici on Sat Nov 07, 2020 11:05 am
ETRTO is there for a reason. Just because it is possible to do something doesn’t mean it’s safe. Just because someone has managed to get away with a particular combination that is not recommended doesn’t mean it will be safe all the time.
gigo91
by gigo91 on Sat Nov 07, 2020 4:36 pm
ETRTO don't even mention 25c wheels for hookless. Zipp, Enve are saying that I can run 27-28 mm tubeless tires on their 25c wheels.
So I, as a customer, don't get it. Are the ETRTO regulations outdated? I can't imagine that Zipp or Enve are giving a green light for something, which don't work... Or has andybody other experiences?
TobinHatesYou
by TobinHatesYou on Sat Nov 07, 2020 9:04 pm
gigo91 wrote: ↑Sat Nov 07, 2020 4:36 pm
Sort of outdated. ETRTO standards up until now have not included tubeless bicycle tires, and thus the specifications for straight-sided or crotchet-style rims were officially meant for tubed clinchers only.
nafaiutb
by nafaiutb on Sat Nov 14, 2020 5:56 am
As for Enve selling things that don't work, just think back to their rims that cut tyre sidewalls, which they tried to blame on the tyre manufacturers. I certainly wouldn't buy their products, nor accept their "green light" that something was safe.
TobinHatesYou
by TobinHatesYou on Sat Nov 14, 2020 7:56 am
nafaiutb wrote: ↑Sat Nov 14, 2020 5:56 am
Uh, it mostly is the clincher tire’s fault, while the rim can contribute as well. The most common cotton clincher + rim failure on this very forum seems to be with Campagnolo Boras, for example.
Pierre86
by Pierre86 on Sat Nov 14, 2020 8:37 am
TobinHatesYou wrote: ↑Sat Nov 14, 2020 7:56 am
Yep
Veloflex even specifically released a set of tires to address this issue, they used to not recommend their tyres for carbon clinchers specifically
S6 Evo
S5 Aero
ultimobici
- in the industry
by ultimobici on Sat Nov 14, 2020 8:51 am
TobinHatesYou wrote:nafaiutb wrote: ↑Sat Nov 14, 2020 5:56 am
Really?? We have a salesperson who has been speccing Vittoria open tubulars on Bora clinchers for years. If this was a real issue we’d have seen warranty returns galore. But we’ve not had so much as one in 10 years plus.
TobinHatesYou
by TobinHatesYou on Sat Nov 14, 2020 9:02 am
ultimobici wrote: ↑Sat Nov 14, 2020 8:51 am
We've had a couple threads on the matter here. One is hidden in an ENVE topic and I'm pretty sure you replied to it. Another very contentious thread involved a pair of WTO 60s. That's not a large sample size, but it's larger than that of ENVE rims on this board. Furthermore, Veloflex and others are making reinforced cotton clincher tires now, so they admit it's a problem. Seems reasonable to point out that the onus is primarily on the tire brands to make less shitty cotton clinchers when this simply is not a problem with vulcanized tires.
