FTFYCorfate wrote: ↑Wed Aug 31, 2022 6:10 pmFirst ride on the r45's tonight.
First impressions is that the front wheel felt pretty twitchy in the wind and was noticeably more affected by the wind than the Vision metron that was on there previously (40mm)
Wheels also felt quite a bit more uncomfortable if that's the right word over bumps, I really felt like I felt every imperfection in the road.
Now that all sounds bad, but I have to say they felt mega quick and the comfort factor is something I'll get used to in time.
The rear wheel flex side to side is super minimal compared to the visions. They also sound ace when rolling along and the freehub sounds great.
Running 23mm gp4000s on them, and they do look noticeably fatter than I was expecting. Couldn't get anything bigger as the clearance on the chainstays is minimal as it is.
Took 15 days to arrive from order, I'm pretty pleased with them!
Winspace Hyper
Forum rules
A friend of mine did manage to buy a rim from them. I think they can sell it to you. But about the new 67 rear rim, the rim depth is different so your current spoke length might be incorrect. And I also noticed that they have changed the spoke angle too so I don't think your current hub and spokes will be compatible...Roadbiker10 wrote: ↑Sun Aug 28, 2022 11:56 pmAlright. That's what I suspected. I'll take the tape of but it doesn't seem like it went further from there. Either way, it is done for.zappafile123 wrote: ↑Sun Aug 28, 2022 11:16 pmNo, it probably can't be fixed. Carbon repair is not really 'fixing' so much as it is making an area structurally sound by patching it - its a bandaid solution. Given the structure and function of that area, its hard to see a bandaide working well. Also be careful pressing - if you can hear it, that means you're making any existing damage worse.Roadbiker10 wrote: ↑Sun Aug 28, 2022 7:14 pmYeah I'm sure now that it is. I can hear the crackling sound when I press on that area. Can that be fixed? There is a guy who fixes carbon frames here in Sweden. I wonder if the wheels can be fixed. Otherwise, can the spokes and hubs be salvaged somehow?
If I were you I'd take the rim tape off to double check. Maybe try the coin test. And if you can confirm its cracked, then the rim probably needs to go in the bin. It's more cost effective and less risky just to buy a new rim from Winspace if they'll sell you one.
I'll have to ask Winspace if they can sell me a rim. Has anyone here ever been in a similar situation as me? I mean needing parts from Winspace? It would be nice if I could get my hands on a new 67 rear rim, and put a 28 on it, with 25 in the front. Otherwise I could use any other rim but it won't look nice.
I know for a fact that they can send just a rim because when the braking track on my 38s deteriorated after only a few 1000 kms they send a replacement rim.cannondale7om wrote: ↑Thu Sep 01, 2022 2:15 amA friend of mine did manage to buy a rim from them. I think they can sell it to you. But about the new 67 rear rim, the rim depth is different so your current spoke length might be incorrect. And I also noticed that they have changed the spoke angle too so I don't think your current hub and spokes will be compatible...Roadbiker10 wrote: ↑Sun Aug 28, 2022 11:56 pmAlright. That's what I suspected. I'll take the tape of but it doesn't seem like it went further from there. Either way, it is done for.zappafile123 wrote: ↑Sun Aug 28, 2022 11:16 pmNo, it probably can't be fixed. Carbon repair is not really 'fixing' so much as it is making an area structurally sound by patching it - its a bandaid solution. Given the structure and function of that area, its hard to see a bandaide working well. Also be careful pressing - if you can hear it, that means you're making any existing damage worse.Roadbiker10 wrote: ↑Sun Aug 28, 2022 7:14 pm
Your next challenge will be to find someone prepared to re-build a wheel with carbon spokes.
My 2c... see what their crash replacement policy is.
Scott Foil RC10 Ultegra 12 speed / Creston 50 - 7.9Kg
2016 Supersix Evo, Non hi mod
Oh yeah. I didn't think about the spoke length. They just told me that they will be able to find a solution, and asked me for the serial number, which is on the hub. We emailed back and forth this morning. Great customer service.cannondale7om wrote: ↑Thu Sep 01, 2022 2:15 amA friend of mine did manage to buy a rim from them. I think they can sell it to you. But about the new 67 rear rim, the rim depth is different so your current spoke length might be incorrect. And I also noticed that they have changed the spoke angle too so I don't think your current hub and spokes will be compatible...Roadbiker10 wrote: ↑Sun Aug 28, 2022 11:56 pmAlright. That's what I suspected. I'll take the tape of but it doesn't seem like it went further from there. Either way, it is done for.zappafile123 wrote: ↑Sun Aug 28, 2022 11:16 pmNo, it probably can't be fixed. Carbon repair is not really 'fixing' so much as it is making an area structurally sound by patching it - its a bandaid solution. Given the structure and function of that area, its hard to see a bandaide working well. Also be careful pressing - if you can hear it, that means you're making any existing damage worse.Roadbiker10 wrote: ↑Sun Aug 28, 2022 7:14 pm
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Thanks for sharing your experience. Yeah, finding someone to work on them might be a challenge. I had contact with a guy who builds wheels here on a Swedish forum. He said the same thing, that he never built with carbon spokes before.SixThirteen wrote: ↑Thu Sep 01, 2022 2:52 amI know for a fact that they can send just a rim because when the braking track on my 38s deteriorated after only a few 1000 kms they send a replacement rim.cannondale7om wrote: ↑Thu Sep 01, 2022 2:15 amA friend of mine did manage to buy a rim from them. I think they can sell it to you. But about the new 67 rear rim, the rim depth is different so your current spoke length might be incorrect. And I also noticed that they have changed the spoke angle too so I don't think your current hub and spokes will be compatible...Roadbiker10 wrote: ↑Sun Aug 28, 2022 11:56 pmAlright. That's what I suspected. I'll take the tape of but it doesn't seem like it went further from there. Either way, it is done for.zappafile123 wrote: ↑Sun Aug 28, 2022 11:16 pm
Would this be something a regular LBS could do? There is one pretty known wheelbuilder here in Stockholm called DR Spoke. I'll see with him, in case I get a rim.
Thank you.Corfate wrote: ↑Thu Sep 01, 2022 10:39 am2016 Supersix Evo, Non hi mod
I´ve ordered the R45 in the 2023 Winspace spec for my older Canyon Ultimate CF SL frame.
Let´s see if 28mm tires will fit. It´s the largest size Canyon says to fit, but I guess this info came from narrower rims some years ago.
lol, damn pretty tight. How many mm clearance you got? You can use an allen key to give a proximate value =P
The wheels looks great on that matte silver frame!
Seems to be about 2mm ish. It's snug to get the allen key in, so maybe 1.5-2mm.ziocomposite wrote: ↑Fri Sep 02, 2022 8:41 pmlol, damn pretty tight. How many mm clearance you got? You can use an allen key to give a proximate value =P
Nothing like cutting it tight eh
And thanks!
I moved to Conti 5000 / 25 for a wheelset for my 2015 Cervelo - they were just that little bit smaller than 4000 / 25Corfate wrote: ↑Sat Sep 03, 2022 9:41 amSeems to be about 2mm ish. It's snug to get the allen key in, so maybe 1.5-2mm.ziocomposite wrote: ↑Fri Sep 02, 2022 8:41 pmlol, damn pretty tight. How many mm clearance you got? You can use an allen key to give a proximate value =P
And thanks!
Ah fantastic, if that's the case i'll pick up some 5000's. These GP4000s are nearly done for and i'm a little bit twitchy with how snug they are!SixThirteen wrote: ↑Wed Sep 07, 2022 6:58 amI moved to Conti 5000 / 25 for a wheelset for my 2015 Cervelo - they were just that little bit smaller than 4000 / 25Corfate wrote: ↑Sat Sep 03, 2022 9:41 amSeems to be about 2mm ish. It's snug to get the allen key in, so maybe 1.5-2mm.ziocomposite wrote: ↑Fri Sep 02, 2022 8:41 pmlol, damn pretty tight. How many mm clearance you got? You can use an allen key to give a proximate value =P
And thanks!
Hyper 65 rim brake wheels owners, what is the braking like?
No info on Winspace site regarding braking surface material, heat resistance, etc.
Are you riding latex inner tubes?
