Zipp 2020
353 with tl tape and valves at 1,305g.
im dying to see more feedback on the new congition v2 hub compared to the old one.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes.
n+1...14 last time i checked, but i lost count
1,306.8g
IG: RhinosWorkshop
IG: RhinosWorkshop
Thanks. About what I expected
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
Ryanw, apologies if you have answered this question earlier in the thread - couldn't find the answer...ryanw wrote:Veloflex Corsa Evo 28c tyre.
Zipp 404 Firecrest - 23mm ID - 29.05mm
Zipp 303 Firecrest - 25mm ID - 30.15mm
Since Veloflex are not on the approved list for Zipp hookless and Veloflex themselves advise against hookless use, did you have any problems mounting and using the tires on Zipp?
I love the tires and considering buying 404FC, so just want to know any experiences from compatibility and usability point of view.
Thank you in advance!
Sent from my SM-G973F using Tapatalk
S-Works Venge 2019 Battleship
Previous bikes:
Canyon Aeroad CF SLX Disc 2019
Canyon Ultimate CF SL Disc
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Yes, at least in Europe...jarm wrote:Are the Zipp 404s allready available?
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Well I have them ( Cognition V2 ) on both my 303's and 454's and I am quite happy with them. Freehub sound is almost silent, coasting is good and bearings are smooth.... really smooth. I can only compare them with my 202's and 404's with the 77/177 hubs.WorkonSunday wrote: ↑Tue Jun 29, 2021 11:40 amim dying to see more feedback on the new congition v2 hub compared to the old one.
IceLed wrote: ↑Wed Jul 07, 2021 8:30 pmRyanw, apologies if you have answered this question earlier in the thread - couldn't find the answer...ryanw wrote:Veloflex Corsa Evo 28c tyre.
They work together amazingly well. Bead locks to rim just fine and when fully deflated, they stay seated.
IG: RhinosWorkshop
IG: RhinosWorkshop
Perfect, appreciate your help! Almost decided on the wheelset, just struggling to find availability... 303 FC vs 404 FC XDR, can't make up my mind
303 FC I can get for like 1450€, 404 FC for about 1700€...
I don't do gravel and I don't care about the crosswind as I am on a heavier side.
The only concern is on the rare occasions when I go on cycling holiday in the Alps, would 404FC behave in the fast descends and not get too twitchy with sudden wind gusts?
But that is like 2-3 weeks a year. For the rest I live in The Netherlands, so as flat as it gets with a lot of wind, deep sections is the way to go.
Still, if 303FC is noticeable better in descending, I would go for them...
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
Previous bikes:
Canyon Endurace AL
Cube Agree C:62
Cube Peloton
404 would be my choice.
IG: RhinosWorkshop
IG: RhinosWorkshop
303 vs 404 isn't going to have a noticeable difference descending, so yeah, I'd also go 404.
Cannondale SSEvo3 'Atticus' - 7.2kg
viewtopic.php?f=10&t=161634
Cannondale Systemsix ’Dante’ - 7.7kg
viewtopic.php?f=10&t=167144
Bought a set of 353s in April.WorkonSunday wrote: ↑Tue Jun 29, 2021 11:40 amim dying to see more feedback on the new congition v2 hub compared to the old one.
The hub lasted 500km before it started to give problems.
You will pedal and then something happens that can be described as a "chain slip". As if the freewheelbody does not engage.
Sent it back to the local importer and after they tested it for a day or two confirmed something was wrong.
That was 2 MONTHS ago. Still waiting for my new rear wheel.
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
The scary thing for me is that no one at Zipp can say "this is what is wrong".......we need to replace THIS. Nobody knows why it does this.
Happens if one of the 3 magnets becomes dislodged. Could have happened in transit by heavy handed folk.Spinnekop wrote: ↑Thu Jul 08, 2021 9:39 amBought a set of 353s in April.WorkonSunday wrote: ↑Tue Jun 29, 2021 11:40 amim dying to see more feedback on the new congition v2 hub compared to the old one.
IG: RhinosWorkshop
IG: RhinosWorkshop
