Roval 2020/2021 Road Wheelsets
Forum rules
zik
by zik
Yes because I don't uderstand, Specialized states that wheels are hookless and are for clincher only, you told me that for hookless is only tubeless tire, so who have right? I just get also confirmation from Grant (GCPerformance on Youtube) that they are hookless and for clincher.
pmprego
by pmprego
zik wrote:
Thu Sep 16, 2021 1:24 pm
Do you have a written reply from roval saying "these are hookless"? If you, please can you post it here?
gSporco
by gSporco
I will remove my tires from my "Current, as in New" Roval Alpinist CL wheelset with DT350 and confirm WTF is going on as I am confused with all this misinformation among all the sites they are described on.
@gSporco - Instagram
Specialized Aethos
State All Road 6061
Retired Cervelo Aspero
zik
by zik
pmprego wrote:
Thu Sep 16, 2021 1:38 pm
No, I had a phone conversation with a representative from specialized.
gSporco
by gSporco
Im still wating for my wheels to arrive, should be here today by 7p EST..
But looking more at Rovals site.. the entire Terra line is Hooked... so why would they make the Alpinist line the "only" one without hooks? I am still in the camp that every Roval wheel has hooks, regardless on what the pictures show.. (I will have eyes on this today to confirm)
Direct from all the Terra wheels description:
"We're hooked
Because versatility is king for all-road performance, we engineered the 25mm internal-width CLX rims to handle tires ranging from 28c to 47c wide, with up to 90 PSI on the 28c rubber. The ability to run a wide range of tire widths as well as a broad swath of pressures allows unparalleled versatility. To ensure both high and low pressure performance, we relied on hook-bead rims."
Specialized Aethos
State All Road 6061
pmprego
by pmprego
"Those Roval wheels are clincher, disc, and tubed tire only. I hope that answers your question!"
Reply from roval themselves. Can we end this discussion? It's only propagating wrong and somehow dangerous information.
gSporco
by gSporco
pmprego wrote:
Thu Sep 16, 2021 6:58 pm
Defining what you mean by "those" would help :)
Specialized Aethos
State All Road 6061
pmprego
by pmprego
gSporco wrote:
Thu Sep 16, 2021 7:20 pm
I've sent them an email today after all that talk about being hookless. I've asked avout the alpinist cl and if they were hookless and thus tubeless.
mhw23
by mhw23
So it looks like they are hookless but not tubeless compatible. They are hookless designed to work with clincher tires and tubes. Do we have consensus?
ckspark
by ckspark
macwatt wrote:
Thu Sep 16, 2021 11:48 am
ckspark wrote:
Thu Sep 16, 2021 9:30 am
macwatt wrote:
Wed Sep 15, 2021 9:21 am
ckspark wrote:
Mon Sep 13, 2021 7:55 am
Does anyone know the recommended or their own spoke tensions for the new Rapide CLX front and rear?
Sorry took me a while to find it
Many thanks, do you have the same for the rear wheel at all?
Oops 😬
Many thanks again.
Nickldn
by Nickldn
mhw23 wrote:
Thu Sep 16, 2021 10:04 pm
I agree, the article linked below is very clear this is the case, it even has a clear photo of the rim. Hookless and not tubless compatible.
https://bikerumor.com/2020/08/24/roval- ... ced-build/
I haven't seen a tyre compatibility list, so I assume all/most clinchers work.
Giant Propel Advanced SL Red Etap 11s Easton EC90 wheels CeramicSpeed BB Zipp SL70 bars 6.5kg
Vitus ZX1 CRS Campy Chorus 12s Bora WTO 45 disk brake wheels Zipp SL70 bars 7.5kg
SL8 build with Craft CS5060 Wheels in progress
pmprego
by pmprego
Did i enter another dimension? Am I in the truman show? There is no such thing as hookless for clincher.
They are simply NOT hookless. They are simply not. They are regular rims WITH hooks for tube only. I don't know what is now the confusion.
From cyclingtips: "While the internal shape features the same hooked 21 mm measurements"
So now it's 2 (roval and cyclingtips) to 1 (bikerumor) in favor of hooked. Can we stop with the nonsense??
gSporco
by gSporco
And I can confirm on my new Roval Alpinist CL with dt350 that the rims "have hooks"
Ill echo that, the Alpinist "Have Hooks".
Specialized Aethos
State All Road 6061
zik
by zik
Thanks gSporco, could you put the wheels on scale? I know how much they weight from internet reviews, but I'd like to hear it from user.
chrisw91
by chrisw91
Simply put, no. A clincher (non-tubeless) tyre cannot be used with a hookless rim according to ETRTO. This is because the clincher tyre standards do not provide sufficiently tight tolerances to 100% ensure safe tyre bead retention.
A hookless rim can still be run with a tubed setup, however the tyre itself must be a tubeless tyre for that tolerance point above.
