Roval 2020/2021 Road Wheelsets
Forum rules
The Rapides have been sold out everywhere, even the Specialized website, for a loooong time. While we all know supply chains remain challenged, does anyone know if the lack of availability is due to that or instead Specialized waiting to release the speculated tubeless version (which I think we all agree was the intention of the current version)?
EVO1 | 5.37kg
EVO3 (sold) | 6.51kg
EVO4 | build thread coming soon
S5 Disc
SystemSix (sold) | 8.01kg
P5 Disc | heavy but fast
S5 Disc
Okay, thanks, 25mm it is then!FlatlandClimber wrote: ↑Thu Mar 11, 2021 10:13 amThe front wheel works great with a 25c or 26c (Specialized TC). A 28c likely is hardly a penalty, but they are designed for 26c TCs.uppis wrote: ↑Thu Mar 11, 2021 7:37 amDoes anyone know are rapides fastest with 25mm or 28mm tires, haven't found anything offical from Specialized? What sizes and tires are people running? I haven't got my wheels yet, but 25mm sounds little wide considering the profile of the wheels. Also going to run tubes for now.
The rearwheel is a different story. It is designed around the 26c also, but they ballon over the rim a little. Aerodynamically, a narrower tire would be faster I guess, but then there is comfort/ confidence and crr... So I guess a 25c/26c is the best compromise here also.
If you are in europe, you can easily get them through webshops like Bike24 from Germany or Lordgun from Italy.refthimos wrote: ↑Fri Mar 12, 2021 4:57 amThe Rapides have been sold out everywhere, even the Specialized website, for a loooong time. While we all know supply chains remain challenged, does anyone know if the lack of availability is due to that or instead Specialized waiting to release the speculated tubeless version (which I think we all agree was the intention of the current version)?
I think they have decided to double down on clinchers now anyway?refthimos wrote: ↑Fri Mar 12, 2021 4:57 amThe Rapides have been sold out everywhere, even the Specialized website, for a loooong time. While we all know supply chains remain challenged, does anyone know if the lack of availability is due to that or instead Specialized waiting to release the speculated tubeless version (which I think we all agree was the intention of the current version)?
I'm not sure about "easily," as Lord Gun is sold out and if you prefer the black graphics over the white graphics, Bike24 appears to have only one front wheel in stock and no rears. With that said, it doesn't look like these are getting restocked - the Specialized website has shown them as unavailable since at least November as far as I can recall.
EVO1 | 5.37kg
S5 Disc
S5 Disc
Bike24 should have wheelsets in stock if you're ok with the white colour way. I ordered a set, will see if/when they arrive.
Good question on whether Roval is coming out with the tubeless version. When I looked into Enve 4.5AR wheels I was told there's a 4 month wait so may just be a general unavailability of parts issue? Would be interesting if anyone has more info on this.
If they do come out with the tubeless Rapide, I'm in.jadedaid wrote: ↑Sat Mar 13, 2021 9:25 amBike24 should have wheelsets in stock if you're ok with the white colour way. I ordered a set, will see if/when they arrive.
Re: the availability of Enve 4.5 AR, it's currently a rim issue, I believe. I had picked up a front wheel for tubeless compatibility and put in an order at Wheelbuilder for a back wheel. While they accepted my order, they told me that they weren't scheduled to have the rim available for months to build and that if I wanted a build, I needed to get myself into the queue. I imagine other places are also in the same boat. That being said, when I put my Rapides back on, the front 4.5 doesn't have anywhere near the kind of stability of the Rapide. But if the shortages persist, it might be a good time for me to sell my lightly used Enve 5.6 Chris King set!
The balooning of the 28s over the rear rim is an illusion. GP5000 28 measures pretty much exactly 28mm when installed. Might go out to 29 after riding. The rear rim width is 30.8mm. It's narrower at the rim-tyre interface though, which gives you that impression of the tyre being wider, but then goes out wider again at about mid point of the rim.FlatlandClimber wrote: ↑Thu Mar 11, 2021 10:13 amThe front wheel works great with a 25c or 26c (Specialized TC). A 28c likely is hardly a penalty, but they are designed for 26c TCs.uppis wrote: ↑Thu Mar 11, 2021 7:37 amDoes anyone know are rapides fastest with 25mm or 28mm tires, haven't found anything offical from Specialized? What sizes and tires are people running? I haven't got my wheels yet, but 25mm sounds little wide considering the profile of the wheels. Also going to run tubes for now.
Btw, I don't know why folks are having troubles mounting tyres on these. I just installed the aforementioned Conti clinchers on these by hand, no problem. I did warm up the tyres a bit before hand on the radiator to about room temperature (so they are not refrigerated - it's damn cold in the shed!), and stretched them by hand a bit before mounting, but really nothing special. Tyres come on/off with no undue difficulty, as long as the beads are in the centre channel.
Well, usually I try to match tire width to the rim interface, not the maximal width at some point. At least for me it makes sense, that the entire rim/ tire combination works as an aero system, not just the tire and the widest point of the wheel. I ride my Swissside wheels for TT with 23c Contis, although the rim is 32mm at the widest point. At the interface however, the transition is silky smooth.
Last edited by FlatlandClimber on Tue Mar 16, 2021 12:53 pm, edited 1 time in total.
Cervelo P5 Disc (2021) 9.1kg
S-Works SL8 (2023) 6.3kg
I guess... Thouhg an alternative theory is that the rim is designed like that for a reason, and if they wanted it to be 30.8mm at the rim-tyre interface, with flat rim sides until the taper at the tip, that could have been easily accomplished.FlatlandClimber wrote: ↑Tue Mar 16, 2021 10:19 amWell, usually I try to match tire width to the rim interface, not the maximal width at some point. At least for me it makes sense, that the entire rim/ tire combination works as an aero system, not just the tire and the widest point of the tire. I ride my Swissside wheels for TT with 23c Contis, although the rim is 32mm at the widest point. At the interface however, the transition is silky smooth.
My set came in today, won't get a chance to ride them until next week. Will be trying these with turbo cottons in 26mm. Intrigued to see how they handle the local european roads where the GP5k have been nigh on indestructible.
Weights are with the standard rim tape they shipped with. Little higher than I was hoping for, but seems on par for the course.
Front: 658g
Rear: 762g
Wheelset: 1420g
Front: 658g
Rear: 762g
Wheelset: 1420g
I think I might have figured out why some of us have been having trouble even getting the first bead on even if you've clearly got the bead in the center channel, whereas others have no problem. It could be the ambient temperature and temperature of the tire rather than your technique.Shrike wrote: ↑Mon Feb 08, 2021 8:38 pmHonestly it's so hard to get it into the channel. I mean seriously it's brutal.
Stuck the other wheelset on for now and thinking of how to proceed. No way these can be my summer wheel/tyre setup for doing epic rides.
Ryan's tubular switch idea could be a confidence booster, I even have a guy locally here whose been helping me with some tricky bike work so I could get him to do the setup while doing another job I want done too shortly (lower front disc brake mount to 140mm - one screw is a bugger and might round out, spent ages getting other one done, not going through that again).
When I was trying to install in a "cold" 60 degree garage, even with the tire in the center channel I couldn't get the first bead on - not even close. Put the tire aside. Now that it's warmer, and I accidentally left the tire in the sun while I was doing something else, the same tire (but warm) popped on easily by hand using the same center channel technique I've used before.
Was wondering this, however spesh have recommended 26 as the most efficient for aero. I stuck to 26.Tonytony wrote:26 or 28mm in front and rear on the rapides? The front wheel is 35mm ext so a 28mm is not a real aero penalty or am I wrong? I'm a little bit worried about the wide front wheel
