Roval 2020/2021 Road Wheelsets
Forum rules
zik
by zik
Does anyone use roval rapide c38 wheels, they are hookles or not, can I run them with continental gp5000 tubeless tires?
yingyu
by yingyu
zik wrote:
Thu Sep 09, 2021 8:49 am
The picture on https://rovalcomponents.com/products/rapide-c-38 has hooks. Hookless road wheel manufacturers (Cadex, Enve, Zipp) usually make a big deal of their hookless designs, which isn't the case for Rapide C38.
jamin
by jamin
I've used that combination without any trouble at all.
tiz92
by tiz92
Hi guys.
I own a SL7 Pro with the CL wheels. Although I have them found to be very fast it seems that they arent that stiff. Especcially the front wheel. When I brake on high speeds (>55kmh) the front wheel wobbles a bit and on tight corners the front wheel doesnt feel very stable. I brought them to my LBS for tensioning 2 times already but it barely changed.
Can somebody confirm this?
I have none issues of this kind on my other wheelset which. They have other disc brake rotors though.
What are your experiences?
macwatt
by macwatt
Could Roval CLX 50's be effected with the DT Swiss Engagement issues?
gSporco
by gSporco
Anyone here using the Roval Alpinist CL wheels? What do you like/ dislike about them? What tires/tubes/ tubeless are you running?
I am taking delivery of a set with my Aethos Pro comming in shortly.. I am also thinking of running them tubeless with 38mm tires on my Diverge.. if it doesnt workout in that mode, Ill sell them, as they are redundant in my current wheelsets that I own..
TIA
@gSporco - Instagram
Specialized Aethos
State All Road 6061
Retired Cervelo Aspero
tbabut
by tbabut
macwatt wrote:
Fri Sep 10, 2021 4:21 pm
I don't think so, because these are equipped with the older 240 hubs (not EXP), which aren't affected.
ckspark
by ckspark
Does anyone know the recommended or their own spoke tensions for the new Rapide CLX front and rear?
macwatt
by macwatt
ckspark wrote:
Mon Sep 13, 2021 7:55 am
Sorry took me a while to find it
zik
by zik
where could I find tire list that are compatible with roval alpinist cl wheels? as I read GP500 are exluced?
spdntrxi
by spdntrxi
zik wrote:
Wed Sep 15, 2021 2:55 pm
why it's not like they are tubeless compatable .. so should be a bunch of non-tubless tires you can run. If you are looking for an "official" tubeless list.. it does not exist.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
zik
by zik
I hesitate beetwen two wheels for hilly training rides: roval c38 and a slightly more expensive (after discount) roval alpinist cl. I would like to lose some weight as my tarmac comp is quite heavy over 8kg.
c38 will allow to run me on tubeless, roval alpinist cl don't
c38 will allow to run gp5000 tubed tire that I like the most, roval alpinist don't (hookles)
roval alpinist have better hubs 350vs370, and are more lightweight.
roval have straight-pull spokes, c38 j-bend
I can't decide.
pmprego
by pmprego
zik wrote:
Wed Sep 15, 2021 5:42 pm
I can't decide.
I've read some c38 reviews that were really bad. But really bad. Try to give them both a run. I dont know.
zik
by zik
Unfortunately test ride is not possibile.
pmprego
by pmprego
zik wrote:
Wed Sep 15, 2021 6:15 pm
I'd have bought the alpinist cl would they be officially tubeless. They are not thus they are not on my list. Nonetheless, the reviews of the c38 are so bad that they are also not on my list.
