Roval 2020/2021 Road Wheelsets
Forum rules
Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
Good info, did he mentioned something regarding clx32?mf22433 wrote:Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
To be honest I didn't ask, I was waiting for his feedback on this new wheelset, so we discussed only the CLX Rapide (I ordered a pair to go with the Venge I am currently building).Pukutis wrote: ↑Sat Feb 15, 2020 2:46 pmGood info, did he mentioned something regarding clx32?mf22433 wrote:Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
BTW he also mentioned that the wheels are now designed first for tubeless and are clincher ready (when in the past they were designed for clincher and were tubeless ready), he said that the new rim bead profile is now different.
Thank you! I will wait till May to see the new models... i am debating between clx32 and 50....mf22433 wrote:To be honest I didn't ask, I was waiting for his feedback on this new wheelset, so we discussed only the CLX Rapide (I ordered a pair to go with the Venge I am currently building).Pukutis wrote: ↑Sat Feb 15, 2020 2:46 pmGood info, did he mentioned something regarding clx32?mf22433 wrote:Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
The Alpaniste is 31mm in depth.Pukutis wrote: ↑Sat Feb 15, 2020 5:00 pmThank you! I will wait till May to see the new models... i am debating between clx32 and 50....mf22433 wrote:To be honest I didn't ask, I was waiting for his feedback on this new wheelset, so we discussed only the CLX Rapide (I ordered a pair to go with the Venge I am currently building).Pukutis wrote: ↑Sat Feb 15, 2020 2:46 pmGood info, did he mentioned something regarding clx32?mf22433 wrote:Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
Alpaniste is an old model, correct?Jhomewood wrote:The Alpaniste is 31mm in depth.Pukutis wrote: ↑Sat Feb 15, 2020 5:00 pmThank you! I will wait till May to see the new models... i am debating between clx32 and 50....mf22433 wrote:To be honest I didn't ask, I was waiting for his feedback on this new wheelset, so we discussed only the CLX Rapide (I ordered a pair to go with the Venge I am currently building).
It's the name of the new lighter disc brake wheel from RovalPukutis wrote: ↑Sat Feb 15, 2020 5:23 pmAlpaniste is an old model, correct?Jhomewood wrote:The Alpaniste is 31mm in depth.Pukutis wrote: ↑Sat Feb 15, 2020 5:00 pmThank you! I will wait till May to see the new models... i am debating between clx32 and 50....mf22433 wrote:
Ok, thank you!! Do you have an indication of the weight? I guess it muss be around 1320gr like Clx32...
I received the confirmation of my order, it says "normally available end of May or June".Pukutis wrote: ↑Sat Feb 15, 2020 5:00 pmThank you! I will wait till May to see the new models... i am debating between clx32 and 50....mf22433 wrote:To be honest I didn't ask, I was waiting for his feedback on this new wheelset, so we discussed only the CLX Rapide (I ordered a pair to go with the Venge I am currently building).Pukutis wrote: ↑Sat Feb 15, 2020 2:46 pmGood info, did he mentioned something regarding clx32?mf22433 wrote:Just had a call from my dealer who attended a presentation where he could see the new CLX Rapide wheels : confirmed 50-60, different profiles front rear, weight similar to CLX50 rim brake version, available in May at the same price as current versions (in Europe).
Cool, look forward to more details perhaps they use a lighter hub in comparison to dt swiss 240...
50/60 clincher lighter then clx32... and still wide.. idk man. Best of luck to Roval... I'm sticking with my CLX32/50/64/321
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
2023 Pivot E-Vault
new CLX Rapide (50/60 db) lighter than CLX50 db (probably identical to CLX50 rim brake)
new Alpiniste (31mm) lighter than CLX32
someone said "lighter then clx32". no question mark , so assumed it was a statement. That would be something. Lighter then 50, I can see that happening although I think CLX50's are not bad.
2023 Pivot E-Vault
2023 Pivot E-Vault
When he said "lighter than CLX32", he was refering to this new "Alpiniste" which is 31mm
