Shallow, wide disc rims recommendations
Hexsense
Re: Shallow, wide disc rims recommendations
Post by Hexsense »
floppyb wrote:
Thu Jan 02, 2020 6:17 am
They seem to recommend everything from a 23c to a 50c will work on that rim. What would be the ideal tyre size for it?
IMO, 21mm internal width's ideal tire size is 25-38mm. With 28-30mm right in the sweetspot.
While i use 25mm tire on 23mm internal width rim, i think it is a bit pushing. 21mm internal width should be better for 25mm tires.
Slammed
Post by Slammed »
Stan's crest? They're shallow, light, and 23mm internal.
Attermann
Post by Attermann »
Slammed wrote:
Fri Jan 03, 2020 5:06 am
But have a 85 kg limit.
FIJIGabe
Post by FIJIGabe »
H Plus Son Hydra rims are 25mm external, 21mm internal (per http://www.bikeman.com/RM4442.html), and come in drillings from 24h to 32h.
I have a set built up for gravel (24/28) and they're rock solid. I also have a set of rims I plan on building up for CX racing (24/24) with some Hope hubs.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
