Shallow, wide disc rims recommendations
floppyb
by floppyb
I'm trying to see what my options are for some rims/wheels that are below 30mm for depth, but still 21mm internal width. Most rims that are below 30mm seem to still be 18mm internal width.
Any suggestions?
Rich_W
by Rich_W
Try the 25mm x 25mm rim from Light Bicycles. I have a pair of clincher rim brake versions on my Emonda SLR - they make a lighter disc version w/o the brake track. Highly recommend
https://www.lightbicycle.com/Carbon-700 ... rface.html
Hexsense
by Hexsense
floppyb wrote:
Mon Dec 30, 2019 4:23 pm
... below 30mm for depth, but still 21mm internal width. Most rims that are below 30mm seem to still be 18mm internal width.
Rich_W wrote:
Mon Dec 30, 2019 4:27 pm
@Rich_W:
Did you read OP's question at all?
That LB is 17.9mm internal width and 25mm external width. Exactly what floppyb state that he don't want.
@floppyb
For your spec, look for gravel/CX rims rather than road.
How about this, 28mm deep, 22mm internal width and 29mm external width.
https://www.lightbicycle.com/29er-disc- ... bikes.html
Matt28NJ
by Matt28NJ
HED Belgium + ... if I understand the question correctly.
mentok
by mentok
Not quite 21mm internal (only 20mm), but I've been really happy with my DT Swiss R470s. 24mm ext, 20mm int, 23mm deep
I haven't tried the DT Swiss RR481, but they do meet your dimension requirements: 26mm ext, 22mm int, 25mm deep
Global
by Global
I have carbonfan 30 deep 22id rims on my tarmac sl6 disc. 1260 grams total with novatec centerlock hubs. 2000 miles so far trouble free 28mm gp 5000 tl tires.
Global :)
Rich_W
by Rich_W
@Rich_W:
Guess I missed that. Didn't realize they're that narrow. LB makes this one that fits the bill
Noctiluxx
by Noctiluxx
Bontrager xxx 2 are 28mm deep, internally 21mm wide.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Cervelo R5 Disk (Team Sunweb)
2019 Giant Revolt Advanced 0
floppyb
by floppyb
Hexsense wrote:
Mon Dec 30, 2019 10:20 pm
@Rich_W:
@floppyb
They seem to recommend everything from a 23c to a 50c will work on that rim. What would be the ideal tyre size for it?
dim
by dim
HED Belgium Plus Eroica:
Trek Emonda SL6
Miyata One Thousand
dlj2119
by dlj2119
EIE Carbon ARG28TC29, 22mm internal width, 28mm deep, SL version 340g
Ferry
by Ferry
dlj2119 wrote:
Thu Jan 02, 2020 5:10 pm
Do you have experience with EIE rims or build wheels?
kytyree
by kytyree
EIE have one on their site at 19.2 mm and 25mm depth that looks pretty good to me. I haven't used anything from them but have stuff from Carbonfan and BTLOS.
RECAR77
by RECAR77
dt 545d 21i/27e, 19mm deep, only 32 holes, 585g
dt xr331 20/24, 18, 28 or 32 holes, 380g (also the cheaper/heavier X392)
dt xr361 22,5/26, 19,5, 28 or 32, 410g (also the cheaper/heavier X412)
mavic xc821 21/24, 20, 28 or 32, 454g
or if you need 24h you can go with dt rr481 (22/26/25/485g) or r500 (22/26/23/495g)
there are probably many other XC rims out there that meet these specifications and XC rims are almost never over 25mm in depth
NickJHP
by NickJHP
DT Swiss XM401. I've built a couple of pairs of wheels with them, and they true up easily and remain true in use. They come supplied with PHR washers and aluminium squorx nipples, and are pretty reasonably priced. Only 28 or 32 drilling, though.
