Nope. I never went with Ryde Big Bull. Too heavy. I'd probably have to go carbon, if I'd want something with a reasonable weight.
Widest alloy rims for rimbrake?
Forum rules
- wheelsONfire
Black Inc Sixty rim brake, hooked rim + 30mm wide.
Bikes:
Open *UP* (2016.04.14)
Cheers, looks competitive to the 30mm AR56 with 23mm internal
https://www.lightbicycle.com/700C-V-sha ... tible.html
Although I'd still probably go LB just because I can pick DT Swiss / I have no interest in ceramic bearings.
Finally used my AR56's in the wet and they do better than expected with the grooved track.
Edit: Added a google doc here
https://docs.google.com/spreadsheets/d/ ... McofeBzLg/
- wheelsONfire
Agree on Ceramic speed bearings. I rather see that as a slight issue instead of a bonus.mechkbfan wrote: ↑Sat Oct 01, 2022 6:11 amCheers, looks competitive to the 30mm AR56 with 23mm internal
This version you have isn't available anymore.
This is the new version
Bikes:
- ultimobici
- in the industry
- Contact:
Why? What benefit are you expecting from +25mm?jesper2913 wrote:I'm considering building a new wheelset for my cx bike with rim brakes. Is there anything wider out there than Hed Belgium + at 25 mm width?
H Plus Son Todestrieb. I have a pair on my rough stuff touring bike, which is running 55mm wide rubber. The rims are 32mm external - can't measure the internal width without taking off the tyres. The rims are definitely not lightweight, though, and only come in 32h or 36h versions.jesper2913 wrote: ↑Sun Dec 29, 2019 12:28 pmI'm considering building a new wheelset for my cx bike with rim brakes. Is there anything wider out there than Hed Belgium + at 25 mm width?
