mavic cosmic lacing
FactoryMatt
by FactoryMatt
noticed something odd on these 2019/20 mavic cosmic pro sl disc. with the front two-cross pattern, the 'outer' spoke doesn't cross UNDER the inner spoke. it DOES, however, with the rear lacing. is there a reason for this? did someone in Romania just not pay attention? the front spokes are twisting a bit because they're not making contact the with second crossed spoke.
thoughts??
EDIT - Mavic got back with me same day and confirmed they're all laced this way. I'm guessing it has to do with bracing angle on the front? idk.
alcatraz
by alcatraz
That's very observant of you. It's a bit odd.
What does the seller tell you?
Wait for a more professional reply but I think some straightpull hub manufacturers have stopped recommending lacing spokes over/under. Maybe a strong enough build benefits very little from it.
FactoryMatt
by FactoryMatt
but the rear is laced over under. the spoke hole offset doesn't seem too severe. just odd theyre inconsistent front to rear wheel
Jugi
by Jugi
Googled close-up product shots of "Mavic cosmic pro sl disc" hubs. All crossing patterns look like the outer spokes aren't crossing under.
FactoryMatt
by FactoryMatt
for both front AND rear?
here, rear crosses, but front doesn't.
FactoryMatt
by FactoryMatt
alcatraz
by alcatraz
I'd check out other wheelsets with the same/similar hubs and see how they are laced.
Just to exclude the possibility of mavic just trying to cover their ass.
