Roadrocket
by Roadrocket on Tue Oct 22, 2019 9:27 am
Alexandrumarian wrote: ↑Mon Oct 21, 2019 3:34 pm
Roadrocket wrote: ↑Mon Oct 21, 2019 8:01 am
Hambini didn´t test the 35s. 15mm in height could do pretty much in difference, you cannot compare that.
Tbh I did imagine the 35 would look similarly good (or bad) as the 50s if tested. In any case I do not blame the difference in the wheel profile but on the tubulars. And i don't use slow tape, but as little as possible mastik. I guess Campa were onto something when they didn't bother with a tubular version for the WTO. Anyway, I am definitly not hating on tubs here. They still feel the best, are arguably safest and lowest weight for hills.
Deeper wheel will be allways faster. I´ve ridden 35s as well, and I´ve found the 50s to be equally good even in the hills, probably because of higher stiffness. Weight is about the same so the 35s doesn´t really make a sense for me.
About tubulars, I ride Vittoria Corsas graphene(glued with Mastik) and I think they are pretty fast even compared to some clinchers(4000 SII). If Campag have made the WTO tubular I´d probably ride them already. But I still like the tubulars more than clinchers, so WTO´s not for me.
Roadrocket
Roadrocket
by Roadrocket on Tue Oct 22, 2019 9:41 am
C36 wrote: ↑Mon Oct 21, 2019 6:36 pm
You have the “faster” / “significantly faster” debate and “faster” / “feel faster” debate.
In terms of feel, on blind-tests, heavier wheels are usually felt as faster by people, then very light wheels for their height like the Boras will somehow feel slower... but at the same time snappier (helped by really good stiffness). It’s always surprising how inertia feeling is totally decorrelated from real measurement on the ground.
Maybe the inertia plays a significant role in case of feeling on the flats. Bora´s are very light for it´s profile(mine about 1220g) so any other 50mm profile wheels weighing 1450g may feel faster because of inertia forces...and maybe they really are.
I ride 23mm on the front to follow the 105% rule, but is it neccessary on the rear wheel as well? I´m allways using 25mm on the rear to improve comfort a bit.
LionelB
by LionelB on Tue Oct 22, 2019 1:34 pm
This thread reminds me that I probably should stock up on Bora 50 tubular before the latest fashion takes them out of the campy catalog. Best wheels ever,
Pierre86
by Pierre86 on Tue Oct 22, 2019 2:32 pm
Roadrocket wrote: ↑Mon Oct 21, 2019 7:58 am
kgt wrote: ↑Sun Oct 20, 2019 7:53 pm
narrower rims with narrow tires have less drag
This really surprised me. So any ,,old school´´ rim, say 21-22mm wide with 20mm tyre on has less drag than 26-27mm wide rim with 25mm tyre? Then the hype about super wide rims is just marketing...
Wide rims are about crosswind stability first with pure speed a close second. The benefits of the wider rim also tend to be the ability to run wider tyres, but those are secondary
S6 Evo
S5 Aero
Alexandrumarian
by Alexandrumarian on Wed Oct 23, 2019 9:29 am
Roadrocket wrote: ↑Tue Oct 22, 2019 9:27 am
50s had two downsides for me: when descending i am spooked by any wind influence and the deep profile was not the best visual match for my frame.
On tires, corsa 1.0 measured better on brr tests and i found the same, 2.0 are kinda sluggish. So i guess it is easy for them to get a solid beating from 5000 with latex. 4000 vs 1.0 should be much closer. Did you have butyl or latex?
Roadrocket
kb1iub
by kb1iub on Sun Nov 03, 2019 10:43 pm
I have a mix of chipseal roads and rough pavement mixes. The local race on Tuesdays takes place in a former army depot. They used to hold the nuclear depth charge, there. I am not kidding.
No one has paved the loop in 50 years. It is so rough in the back stretch.
I've taken the gp4000 through it on many occasions. Right now I think that the stiff enve with a 25mm Victoria graphene tire is comfy on the back. It took the sting of the gp4000 away.
I thought that the pressures on the tire were causing the clincher wall to come into contact with the pavement. I'm flying over the same stretch in the tubular. What are the thoughts on this ?
Am I imagining this ? Is the comfort increase only due to the wheel ? The wheels are stiffer in the 2nd setup. The gp4000 is on cheap aluminum dt Swiss.
Bill
Sent from my Moto E (4) using Tapatalk
ultyguy
by ultyguy on Fri Nov 08, 2019 5:30 pm
Yup, I’ve got Bora One 50 tubular and have found them to be a very fast all around wheel and I ride 25mm tubs. With the AC3 braking surface, they are probably the best bang for buck wheel out there imho as they’re also very light <1300g.
The test is probably done at low yaw as well hence you lack separation between rim depths/designs etc. the wide wheels really shine at 10 deg+ yaw as the air still sticks to them and gives the a little sail effect.
FWIW I also have ZIPP 404 firecrest tubs that I also 25mm tubs on. On flat to rolling terrain they do feel faster more through the fact that they’re a bit heavier and hold speed better.
Horses for courses I guess but the Bora 50 is hard to beat
- 10 Replies
- 1156 Views
Last post by guyc
Thu Feb 21, 2019 8:26 am
- 15 Replies
- 991 Views
Last post by Calnago
Fri Jul 26, 2019 11:52 pm
- 1 Replies
- 287 Views
Last post by LewisK
Wed Nov 06, 2019 12:13 pm
- 0 Replies
- 205 Views
Last post by pritchet74
Tue Nov 19, 2019 6:06 pm
- 3 Replies
- 217 Views
Last post by kgt
Sat Nov 09, 2019 7:01 pm
