Hunt limitless VS Roval CL 50
pmprego
by pmprego
I've settled on these two 50mm options: the new very wide hunt limitless disc wheels and the roval CL 50 disc (the clx are just to expensive).
Now the thing is that even though I have very limited experience in racing what I've found out is that aero is NOT everything. It maybe for TT and thriatlon but for group racing the draft effect makes it a very different "world". In group racing (kind of classics racing) what I've found out is that the deciding moments usually happen during small but steep hills or even long climbs if it's a mountain stage. In these I've also found out that my 1900gr current wheels are just heavy as hell.
So, my question is, given this context, should I go for the 1515gr roval (350 DT hub) or the 1580gr hunt wheel (ceramicspeed bearings)?
VTR1000SP2
by VTR1000SP2
In your consideration, did you look at either Light Bicycle or FSE rims with a set of Carbon-Ti hubs? They would be more competitive weight wise and the build would be laterally quite stiff. The lower weight and stiffness would help you react well to attacks.
pmprego
by pmprego
It will have to be disc wheels and I would prefer complete build otherwise I would have to take it to a bike shop to assemble.
Nonetheless, from your comment I can deduce that you are somewhat saying "go for the lighter ones".
Dannnnn
by Dannnnn
Having recently got the Rovals, They are brilliant.
I went for the them becasue A. they match my specialized bike and B they have DT hubs.
My only gripe is that the freehub is silent. Whereas the hunts will have a redicloulously loud freehub.
Broady
by Broady
Saw the Hunts recently, they look amazing. Think I'm going to grab a set for my Mrs for Xmas.
pmprego
by pmprego
I guess I prefer them silent for snicky attacks 😁😁
hannawald
by hannawald
+1 on Light Bicycle RR56C02 disc rims with Carbon Ti hubs. They will be 1400g, maybe sub 1400g. That´s worth the hassle with going to your LBS to complete them.
Wookski
by Wookski
Have Hunt’s rim designs changed since Hambini’s aero test where their 50mm design only tested 3W better than a mavic kysrium?
Visus
by Visus
hannawald wrote:
Mon Sep 23, 2019 1:24 pm
Why? They will happily build them for you with Carbon-Ti Hubs
by Nefarious86
CL50. Simple and reliable build.
Sent from my SM-G977B using Tapatalk
Using Tapatalk
pmprego
by pmprego
Wookski wrote:
Mon Sep 23, 2019 1:41 pm
In theory, hunt developed a new 50mm wheel which they called limitless. Compared to the ones hambini tested, these are 50% more expensive (in part due to the ceramicspeed stuff). I hope they are a better design that the one hambini tested.
JayDee81
by JayDee81
pmprego wrote:
Mon Sep 23, 2019 2:11 pm
Maybe the most important thing to note is that they are 35mm outer and 22.5mm inner width and Hunt says that they are aerodynamically optimised for 25-28c tyres.
spdntrxi
by spdntrxi
Nefarious86 wrote:
Mon Sep 23, 2019 2:03 pm
this
AJS914
by AJS914
Specialized has a good wheel warranty: Lifetime from defects and 2 year crash replacement.
Campervan
by Campervan
No Rovals on that report either. If Hunt 50's are so bad, why they they been on the podium on the tour de Britain last year?
BMC Granfondo 02 105
Scott Scale 940
Boardman CXR 9.4 cxr CX/gravel mongrel
Btwin 540
Specialized Venge Pro Disc
