Need help with spokes length
maxwkh
by maxwkh
Hello fellow WWs,
This is my first wheels build and I need help on getting the right spokes length, getting paranoid because I got the wrong spokes once resulted from miscalculated ERD by 2mm extra.
I have since recalculated the ERD again, again and again and confirmed it is 590mm (ZTR Grail before the carbon version model)
The issue now is with DT Swiss calculator, it shows the spokes sizes as below:
FL: 297.4mm
FR: 298.5mm
RL: 298.6mm
RR: 298.2mm
However the suggested length are different:
FL: 295mm
FR: 296mm
RL: 297mm
RR: 296mm
Questions is:
- The number is almost 2.5mm difference in the case of FR, isn't that too much?
- Which one should I follow?
- Do I round up since usually spoke only available in even length?
- Do I need to compensate with different value for different spoke nipple?
Spoke will be Pillar 1420 - 14G with generic spoke nipple (I measured the spoke nipple length from the mistaken batch, it is 14mm with around 10mm of thread).
To peoples who have experience in wheels building, any suggestion?
Thank you for reading and your time!
P/S: I have ordered 300mm and 280mm previously - should have been 298mm, but brain mistaken 2mm with 2cm (-‸ლ), feel free to suggest ways to reuse some of it if possible.Image
bm0p700f
by bm0p700f
The problem is you cant select a pillar nipple. You selected a dt 14mm nipple and that took 2mm of the spoke lengths due to the funny way dt nipples work. Round down from the calculated lengths and go with that.
maxwkh
by maxwkh
bm0p700f wrote:The problem is you cant select a pillar nipple. You selected a dt 14mm nipple and that took 2mm of the spoke lengths due to the funny way dt nipples work. Round down from the calculated lengths and go with that.
Since I can only get even spoke length, does it mean I should go with the following lengths (round down)?
FL: 296mm
FR, RL, RR: 298mm
Or it is better to go all 298mm?
Thank you.
MikeD
by MikeD
Use another spoke calculator such as https://www.wheelpro.co.uk/spokecalc/
bm0p700f
by bm0p700f
Your lengths seem to be 298mm all round. I would use spokecalc though.
alanyu
by alanyu
The spoke will be pulled longer under tension, and I think that's why the suggested length are 2.5mm shorter.
plus: aerolite is worse than cx-ray under high tension, but not cheaper.
maxwkh
by maxwkh
Thanks for the suggestions, this is what I got with the wheelpro's calculator and rounding method
Left
Right
According this is rounding tables, the spokes I need will be
Front: 298mm, 300mm
Rear: 300mm, 298mm
According to this thread I can use 2-4mm longer spokes with DSN nipple
viewtopic.php?t=149132
Since I have 300mm spokes, so I ordered the DSN nipple and will try to build one of the wheel to see if it work.
bm0p700f
by bm0p700f
Spokes dont stretch by 2.5mm
bm0p700f
by bm0p700f
With straight pull spokes you cant use any other spoke calculator than dt swiss currently. Go with 298mm all round with non dt swiss nipples or dt swiss suggested length with there 14mm nipples
maxwkh
by maxwkh
Alright. 298mm is it then. Thank you very much.
Sent from my A0001 using Tapatalk
