New to disc brakes and a bit confused with the compatibility between through axles and framesets. I'm considering Cervelo R5 disc which comes with proprietary 12mm t/a.'s front and rear. Wondering if or how the frame accepts larger diameter through axles?
I understand wheelset brands use different size t/a's, but I'm not sure if the frame is compatible with other size through axles? For example, if I'm using the original 12mm axles and decide to use different wheels requiring a 15mm axle, would I just need an adapter for the hub/wheelset and continue to use the same 12mm axles?
I hope this makes sense?
Thanks in advance
Through axles question
No, you would only ever use wheels with 12mm endcaps installed. 15mm TA is for MTB and some chunky early gravel bikes.
Wheels/hubs are otherwise TA agnostic. If the 12mm endcaps are installed on the hub, then that wheel can be used with any bike that uses 12x100 / 12x142mm TA.
