DT Thru-Bolts (not thru-axles)
Valbrona
by Valbrona
DT website says my P1800 Spline Disc Brake REAR Wheel only needs the end caps changing in order to run a 10mm RWS Thru-Bolt.
My wheels: https://www.dtswiss.com/en/products/whe ... spline-32/
The end caps I think I need: HWGXXX0006560S
AGREE? I NOTICE SOME DT HUBS ALSO REQUIRE THE REPLACEMNT OF THE AXLE, BUT I DON'T KNOW WHY THIS IS THE CASE.
Absolutely nothing on the DT website mentioning the running of a 9mm thrU-bolt in the front.
Thanks folks.
jfranci3
by jfranci3
It's pretty clear here https://www.dtswiss.com/en/support/conv ... road-rear/ and they're all the same for 10mm.
For the front, I don't see why HWGXXX00S3803S wouldn't work.
Valbrona
by Valbrona
jfranci3 wrote:
Thu Jun 27, 2019 10:48 pm
That's what I think as well. Strange there seems to be no mention of front thru-bolts on the DT website.
Thanks.
jfranci3
by jfranci3
You can also drill out the QR end cap
Valbrona
by Valbrona
jfranci3 wrote:
Fri Jun 28, 2019 12:04 am
Thanks. I thought of that.
Could have also fitted 15>9mm reducers into 15mm end caps, but decided against this.
jfranci3
by jfranci3
The TA end caps resell pretty well FYI. You can get close to full price on the unused 15mm or 12mm one they included
